ONTAP performance counter mapping
nvmf_lif
An NVMe/FC LIF is a logical interface that connects an SVM to a NVMe/FC capable physical port. This table collects diagnostics and performance information for an NVMF LIF. The table counters can be used to debug and diagnose connectivity issues with initiators or fabric on a LIF. The table counters can be used to debug and diagnose connectivity issues with initiators or fabric at a LIF level granularity. The alias names for nvmf_lif:node and nvmf_lif:port are nvmf_lif_node and nvmf_lif_port respectively.
Classic Object: nvmf_fc_lif
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{node.name}:{instance_name}:{instance_uuid}
constituent
This represents the construction of a row ID field for a row from a single node.
{port_id}:{port_wwpn}
port
This represents the construction of the row ID field in port combo object, which is a single unique string that identifies a row.
{node.name}:{node.uuid}
node
This represents the construction of the row ID field in node combo object, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Node name
node_uuid
node.uuid
Node UUID
instance_name
name
Name of this logical interface (LIF)
instance_uuid
uuid
UUID of this logical interface (LIF)
aggregated_lif_uuid
aggregated_lif_uuid
Aggregated NVMF logical interface row ID
aggregated_lif_name
aggregated_lif_name
Aggregated NVME LIF name
vserver_name
svm.name
Name of the SVM (formerly referred to as a Vserver) that owns this logical
interface (LIF)
vserver_uuid
svm.uuid
UUID of the SVM (formerly referred to as a Vserver) that owns this logical
interface (LIF)
port_wwpn
port_wwpn
WWPN for the port
port_id
port_id
ID for the port
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
read_ops
read_ops
Number of read operations
write_ops
write_ops
Number of write operations
compare_ops
compare_ops
Number of compare operations
caw_ops
caw_ops
Number of compare and write operations
other_ops
other_ops
Number of operations that are not read, write, compare or compare-and-write.
total_ops
total_ops
Total number of operations.
remote_read_ops
remote_read_ops
Number of remote read operations
remote_write_ops
remote_write_ops
Number of remote write operations
remote_compare_ops
remote_compare_ops
Number of remote compare operations
remote_caw_ops
remote_caw_ops
Number of remote compare and write operations
remote_other_ops
remote_other_ops
Number of remote operations that are not read, write, compare or compare-and-
write.
remote_total_ops
remote_total_ops
Total number of remote operations.
read_data
read_data
Amount of data read from the storage system
write_data
write_data
Amount of data written to the storage system
compare_data
compare_data
Amount of data compared in the storage system
caw_data
caw_data
Amount of data compared and written to in the storage system
total_data
total_data
Amount of NVMF traffic to and from the storage system
remote_read_data
remote_read_data
Amount of remote data read from the storage system
remote_write_data
remote_write_data
Amount of remote data written to the storage system
remote_compare_data
remote_compare_data
Amount of remote data compared in the storage system
remote_caw_data
remote_caw_data
Amount of remote data compared and written to in the storage system
remote_total_data
remote_total_data
Amount of NVMF remote traffic to and from the storage system
avg_read_latency
average_read_latency
Average latency for read operations
avg_write_latency
average_write_latency
Average latency for write operations
avg_other_latency
average_other_latency
Average latency for operations other than read, write, compare or compare-and-
write.
avg_latency
average_latency
Average latency for NVMF operations
remote_avg_read_latency
remote_average_read_latency
Average latency for remote read operations
remote_avg_write_latency
remote_average_write_latency
Average latency for remote write operations
remote_avg_other_latency
remote_average_other_latency
write.
remote_avg_latency
remote_average_latency
Average latency for NVMF remote operations
read_latency_hist
read_latency_histogram
Latency histogram for read operations
remote_read_latency_hist
remote_read_latency_histogram
Latency histogram for remote read operations
pend_q_hist
pending_queue_histogram
Latency histogram when IOs are placed in pending queue
driver_read_latency_hist
driver_read_latency_histogram
Driver latency histogram for read operations. Records the time spent in the
protocol stack for read operations.
storage_read_latency_hist
storage_read_latency_histogram
Storage latency histogram for read operations. Records the time spent in storage
write_latency_hist
write_latency_histogram
Latency histogram for write operations
remote_write_latency_hist
remote_write_latency_histogram
Latency histogram for remote write operations
driver_write_latency_hist
driver_write_latency_histogram
Driver latency histogram for write operations. Records the time spent in the
protocol stack for write operations.
storage_write_latency_hist
storage_write_latency_histogram
Storage latency histogram for write operations. Records the time spent in
storage for write operations.
fabric_latency_hist
fabric_latency_histogram
Fabric latency histogram for write operations. Records the time spent in the
fabric after sending a transfer-ready to get WRITE data.
read_size_hist
read_size_histogram
Histogram of read sizes
write_size_hist
write_size_histogram
Histogram of write sizes
remote_read_size_hist
remote_read_size_histogram
Histogram of remote read sizes
remote_write_size_hist
remote_write_size_histogram
Histogram of remote write sizes
read_cmd_proc_latency_hist_8K
read_cmd_processing_latency_histogram_8K
Histogram for read command processing and data delivery time for I/O less
than/equal to 8K.
read_cmd_proc_latency_hist_16K
read_cmd_processing_latency_histogram_16K
Histogram for read command processing and data delivery time for I/O greater
than 8K AND less than/equal to 16K.
read_cmd_proc_latency_hist_32K
read_cmd_processing_latency_histogram_32K
than 16K AND less than/equal to 32K.
read_cmd_proc_latency_hist_64K
read_cmd_processing_latency_histogram_64K
than 32K AND less than/equal to 64K.
read_cmd_proc_latency_hist_large_io
read_cmd_processing_latency_histogram_large_io
than 64K.
remote_read_cmd_proc_latency_hist_8K
remote_read_cmd_processing_latency_histogram_8K
Histogram for remote read command processing and data delivery time for I/O less
than/equal to 8K.
remote_read_cmd_proc_latency_hist_16K
remote_read_cmd_processing_latency_histogram_16K
greater than 8K AND less than/equal to 16K.
remote_read_cmd_proc_latency_hist_32K
remote_read_cmd_processing_latency_histogram_32K
greater than 16K AND less than/equal to 32K.
remote_read_cmd_proc_latency_hist_64K
remote_read_cmd_processing_latency_histogram_64K
greater than 32K AND less than/equal to 64K.
remote_read_cmd_proc_latency_hist_large_io
remote_read_cmd_processing_latency_histogram_large_io
Histogram for remote remote read command processing and data delivery time for
I/O greater than 64K.
write_cmd_proc_latency_hist_8K
write_cmd_processing_latency_histogram_8K
Histogram for write command processing and data delivery time for I/O less
than/equal to 8K.
write_cmd_proc_latency_hist_16K
write_cmd_processing_latency_histogram_16K
Histogram for write command processing and data delivery time for I/O greater
write_cmd_proc_latency_hist_32K
write_cmd_processing_latency_histogram_32K
write_cmd_proc_latency_hist_64K
write_cmd_processing_latency_histogram_64K
write_cmd_proc_latency_hist_large_io
write_cmd_processing_latency_histogram_large_io
than 64K.
remote_write_cmd_proc_latency_hist_8K
remote_write_cmd_processing_latency_histogram_8K
Histogram for remote write command processing and data delivery time for I/O
less than/equal to 8K.
remote_write_cmd_proc_latency_hist_16K
remote_write_cmd_processing_latency_histogram_16K
remote_write_cmd_proc_latency_hist_32K
remote_write_cmd_processing_latency_histogram_32K
remote_write_cmd_proc_latency_hist_64K
remote_write_cmd_processing_latency_histogram_64K
remote_write_cmd_proc_latency_hist_large_io
remote_write_cmd_processing_latency_histogram_large_io
greater than 64K.
write_data_consume_latency_hist_8K
write_data_consume_latency_histogram_8K
Histogram for write data consumption time for I/O less than/equal to 8K.
write_data_consume_latency_hist_16K
write_data_consume_latency_histogram_16K
Histogram for write data consumption time for I/O greater than 8K AND less
than/equal to 16K.
write_data_consume_latency_hist_32K
write_data_consume_latency_histogram_32K
Histogram for write data consumption time for I/O greater than 16K AND less
than/equal to 32K.
write_data_consume_latency_hist_64K
write_data_consume_latency_histogram_64K
Histogram for write data consumption time for I/O greater than 32K AND less
than/equal to 64K.
write_data_consume_latency_hist_large_io
write_data_consume_latency_histogram_large_io
Histogram for write data consumption time for I/O greater than 64K.
remote_write_data_consume_latency_hist_8K
remote_write_data_consume_latency_histogram_8K
Histogram for remote write data consumption time for I/O less than/equal to 8K.
It includes remote transport latency and remote WAFL latency.
remote_write_data_consume_latency_hist_16K
remote_write_data_consume_latency_histogram_16K
Histogram for remote write data consumption time for I/O greater than 8K AND
less than/equal to 16K. It includes remote transport latency and remote WAFL
latency.
remote_write_data_consume_latency_hist_32K
remote_write_data_consume_latency_histogram_32K
Histogram for remote write data consumption time for I/O greater than 16K AND
less than/equal to 32K. It includes remote transport latency and remote WAFL
latency.
remote_write_data_consume_latency_hist_64K
remote_write_data_consume_latency_histogram_64K
Histogram for remote write data consumption time for I/O greater than 32K AND
less than/equal to 64K. It includes remote transport latency and remote WAFL
latency.
remote_write_data_consume_latency_hist_large_io
remote_write_data_consume_latency_histogram_large_io
Histogram for remote write data consumption time for I/O greater than 64K. It
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
Classic Object Alias
nvmf_lif:port
nvmf_lif_port
nvmf_lif:node
nvmf_lif_node
