ONTAP performance counter mapping
wafl_hya_per_aggregate
CM object for exporting Flash Pool per-aggregate statistics.
Classic Object: wafl_hya_per_aggr
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
hya_aggr_name
hya_aggregate_name
Name of the Flash Pool.
vol_name
volume.name
Name of the volume.
vserver_name
svm.name
Name of the SVM owning this volume
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
ssd_total
ssd_total
Total SSD blocks.
ssd_total_used
ssd_total_used
Total SSD blocks used.
ssd_available
ssd_available
Total SSD blocks available.
ssd_direct_allocated
Total SSD blocks direct allocated.
ssd_read_cached
ssd_read_cached
Total read cached SSD blocks.
ssd_write_cached
ssd_write_cached
Total write cached SSD blocks.
hya_read_hit_latency_hist
hya_read_hit_latency_histogram
Flash Pool RAID I/O read latency with cache hit.
hya_read_hit_latency_count
Total read hit latency samples collected.
hya_read_hit_latency_average
Average of RAID I/O latency on read hit.
hya_read_miss_latency_hist
hya_read_miss_latency_histogram
Flash Pool RAID I/O read latency with a cache miss.
hya_read_miss_latency_count
Total read miss latency samples collected.
hya_read_miss_latency_average
Average read miss latency.
hya_write_ssd_latency_hist
hya_write_ssd_latency_histogram
Flash Pool raidio write latency to SSD.
hya_write_ssd_latency_count
Total write SSD latency samples collected.
hya_write_ssd_latency_average
Average of RAID I/O latency on write to SSD.
hya_write_hdd_latency_hist
hya_write_hdd_latency_histogram
Flash Pool raidio write latency to HDD.
hya_write_hdd_latency_count
Total write HDD latency samples collected.
hya_write_hdd_latency_average
Average write latency to HDD.
read_ops_replaced
read_ops_replaced
Number of HDD read operations replaced by SSD reads per second.
read_ops_total
read_ops_total
Number of non-Flash Pool metafile read operations per second.
read_ops_replaced_percent
Percentage of HDD read operations replace by SSD.
read_ops_blks_total
read_ops_blocks_total
Number of non-Flash Pool metafile blocks read operations per second.
read_blks_replaced_percent
read_blocks_replaced_percent
Percentage of HDD block reads replaced by SSD.
write_blks_replaced
write_blocks_replaced
Number of HDD write blocks replaced by SSD writes per second.
wc_write_blks_total
wc_write_blocks_total
Number of write-cache blocks written per second.
wc_write_blks_replaced_percent
wc_write_blocks_replaced_percent
Percentage of write-cache block written getting overwritten (to SSD or HDD).
est_write_blks_total
estimated_write_blocks_total
Estimated number of HDD blocks written per second on a non-Flash Pool.
hdd_write_blks
hdd_write_blocks
Total HDD blocks written.
write_blks_compensate
write_blocks_compensate
Number of write blocks compensation for operation saved calculation.
evict_destage_raw
evict_destage_raw
Raw write-cache destaged block count.
Percentage of blocks overwritten to write-cache among all disk writes.
read_rc_nra_hit_type
Block types of non-read-ahead read hits to read cache.
read_rc_nra_hit_blks_rate
read_rc_nra_hit_blocks_rate
Number of blocks of non-read-ahead read hits to read cache.
read_rc_ra_hit_type
read_rc_ra_hit_type
Block types of read-ahead read hits to read cache.
read_rc_ra_hit_blks_rate
read_rc_ra_hit_blocks_rate
Number of blocks of read-ahead read hits to read cache.
read_wc_nra_hit_type
Block types of non-read-ahead read hits to write cache.
read_wc_nra_hit_blks_rate
read_wc_nra_hit_blocks_rate
Number of blocks of non-read-ahead read hits to write cache.
read_wc_ra_hit_type
read_wc_ra_hit_type
Block types of read-ahead read hits to write cache.
read_wc_ra_hit_blks_rate
read_wc_ra_hit_blocks_rate
Number of blocks of read-ahead read hits to write cache.
read_miss_type
read_miss_type
Block types of read misses.
read_miss_blks_rate
read_miss_blocks_rate
Number of block misses in SSD cache.
evict_cool
evict_cool
Number of temperature decrements done.
evict_cool_temp
evict_cool_temperature
Number of temperature decrements done per temperature.
evict_destage
evict_destage
Number of temperature decrements result in a block destage.
evict_destage_rate
evict_destage_rate
Number of block destage per second.
evict_remove
evict_remove
Number of temperature decrements that result in a block free.
evict_remove_rate
evict_remove_rate
Number of block free per second.
evict_skip_map
evict_skip_map
Number of eviction blocks skipped for map conflict.
evict_skip_hit
evict_skip_hit
Number of eviction blocks skipped due to pending hit update.
evict_skip_bad
evict_skip_bad
Number of eviction blocks skipped due to corruption in the cachemap entry.
evict_reasons
evict_reasons
Reasons for eviction running or not.
hhu_chunk_alloc
hhu_chunk_allocations
Number of allocations of buffers containing HyA hit update records.
hhu_chunk_applied
hhu_chunk_applied
Number of buffers containing hit update records applied to aggregates.
hhu_chunk_empty
hhu_chunk_empty
Number of buffers containing hit update records freed after all records removed.
hhu_chunk_enospace
hhu_chunk_enospace
Number of buffers containing hit update records after ssd is full.
hhu_chunk_purged
hhu_chunk_purged
Number of buffers containing hit update records purged without applying.
hhu_vbn_added
hhu_vbn_added
Count of hit update records added.
hhu_vbn_added_lo_ret
hhu_vbn_added_lo_retention
Count of hit update records added for low cache retention priority volumes.
hhu_vbn_added_hi_ret
hhu_vbn_added_hi_retention
Count of hit update records added for high cache retention priority volumes.
hhu_range_clear
hhu_range_clear
Count of hit update records removed due to eviction.
hhu_nomem
hhu_no_memory
Count of hit update records removed due to no memory.
hhu_susp_mem_alloc
hhu_suspended_memory_allocation
Count of hit update suspended due to memory allocation.
hhu_susp_load_active
hhu_suspended_load_active
Count of hit update suspended due to load active.
hhu_susp_load_ttmap
hhu_suspended_load_ttmap
Count of hit update suspended due to Type and Temperature Map (TTMap) load.
hhu_susp_cow_ttmap
hhu_suspended_cow_ttmap
Count of hit update suspended due to ttmap cow.
hhu_susp_dirty_ttmap
hhu_suspended_dirty_ttmap
Count of hit update suspended due to Type and Temperature Map (TTMap) dirty.
hhu_susp_yield
hhu_suspended_yield
Count of hit update suspend yield.
hhu_susp_in_cp
hhu_suspended_in_cp
Count of hit update suspended in CP.
hhu_mod_skipped
hhu_mod_skipped
Count of hit update skipped due to modified buffer.
hhu_chunk_alloc_pool
hhu_chunk_allocation_pool
Allocated memory chunks for tracking the read hits from free pool.
hhu_chunk_free_pool
hhu_chunk_free_pool
Freed memory chunks for tracking the read hits to free pool.
hhu_msgpool_grown
hhu_msgpool_grown
Number of times hit update apply msgpool grew.
hhu_msgpool_shrunk
hhu_msgpool_shrunk
Number of times hit update apply msgpool shrunk.
read_cache_ins_type
read_cache_inserts_type
Block types of cache inserts.
read_cache_ins_blk_total
read_cache_insert_block_total
Cache insert block count.
read_cache_ins_rate
read_cache_insert_rate
Cache insert rate blocks/sec.
cache_rej_type
cache_reject_type
Block types of rejected cache inserts.
cache_reject_nospace
cache_reject_no_space
Cache insertion rejects because there is no space.
cache_rej_reason_dist
cache_reject_reason_distribution
Flash Pool cache insert reject reason distribution.
cache_rej_reason_public_dist
cache_reject_reason_public_distribution
Flash Pool cache insert reject reason public distribution.
random_cache_dirty
random_non_mbuf_cache_dirty
Number of non-mbuf random cache dirties.
random_mbuf_cache_dirty
Number of mbuf random cache dirties.
blkr_rejected_cached_on_ssd
Total HDD blocks that were not relocated because they were SSD cached.
blkr_rejected_ssd_rgs
Total number of times SSD rgs were skipped during blkr or CSC.
ssd_cache_freed
ssd_cache_freed
Number of cached SSD blocks freed.
ttmap_refs_saturated
ttmap_references_saturated
Number of references of cached block that do not result in the increase of
reference count of Type and Temperature Map (TTMap) due to limited bits.
dropped_hit_updates
dropped_hit_updates
Number of references of cached blocks that happen before the hit update scanner
reaches it from last time the reference happens. This results in a dropped
reference count.
wc_write_blks
wc_write_blocks
Block types of write-cached block.
direct_write_blks
direct_write_blocks
Block types of writes of directly allocated SSD blocks.
direct_read_blks
direct_read_blocks
Block types of reads of directly allocated SSD blocks.
direct_read_ra_blks
direct_read_ra_blocks
Block types of read-aheads of directly allocated SSD blocks.
wc_l0_flag
wc_l0_flag
Write-caching L0s flagged for WS.
wc_seq
wc_seq
Write-caching L0s deemed sequential.
wc_wafe_sees_seq
wc_wafe_deflagged
Write-caching WAFE deflagged.
wc_blks_ow_to_ssd
wc_blocks_overwrite_to_ssd
Write-caching overwrite to SSD.
wc_blks_ow_to_hdd
wc_blocks_overwrite_to_hdd
Write-caching overwrite blocks to HDD.
blkr_ssd_read_io
blkr_ssd_read_io
Number of block relocation (blkr) SSD read I/Os.
blkr_ssd_read_blks
blkr_ssd_read_blocks
Number of block relocation (blkr) SSD read blocks.
cachemap_partition_blks
cachemap_partition_blocks
Number of HDD blocks per cachemap partition.
cachemap_partition_count
Number of cachemap partitions.
hitupdate_complete_scans
Number of hitupdate complete scans.
hitupdate_ttmap_bufs_dirtied
hitupdate_ttmap_buffers_dirtied
Number of Type and Temperature Map (TTMap) buffers dirtied by the hitupdate
scanner.
hitupdate_steps
hitupdate_steps
Number of hitupdate scan steps.
hitupdate_starts
hitupdate_starts
Number of hitupdate scan message starts.
hitupdate_suspends
hitupdate_suspends
Number of times hitupdate scan msg suspended voluntarily.
hitupdate_active_bits_seen
Number of active flags the hitupdate scanner processed.
hitupdate_ra_blk_attempts
hitupdate_ra_block_attempts
Number of blocks the hitupdate scanner attempted to read ahead.
hitupdate_blks_accessed
hitupdate_blocks_accessed
Number of blocks the hitupdate scanner accessed.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
The labels have changed from "0 - <1ms" to "0_to_<1ms".
For each of the new labels in this array, the values have been changed to
be lower case and any other non alpha-numeric characters have been replaced
by an underscore.
read_rc_ra_hit_type
by an underscore.
by an underscore.
read_wc_ra_hit_type
by an underscore.
read_miss_type
by an underscore.
The labels have changed from "2→1" to "1_to_2".
evict_reasons
The labels have changed from "maint mode" to "maintenance_mode".
by an underscore.
cache_reject_type
by an underscore.
The labels have changed from "buf_needs_iron" to "buffer_needs_iron".
wc_write_blocks
by an underscore.
Table Aliases
This section describes aliases for aggregated tables.
