ONTAP performance counter mapping
nic_common
This table tracks hardware network traffic performance and errors for all supported network interface cards (NIC), such as Intel Niantic, Qlogic, and CNA.
Classic Object: nic_common
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Node name.
node_uuid
node.uuid
Node UUID
nic_type
type
NIC card type, such as ixgbe or qlge
link_current_state
link_current_state
Current link state
link_media_state
link_media_state
Current media state is active or no carrier
link_duplex
link_duplex
Link duplex setting is half or full
link_speed
link_speed
Link speed
link_flowcontrol
link_flowcontrol
Current link flow control state (Transmit or Receive or Both)
rss_enabled
rss_enabled
Indicates whether the interface is enabled for RSS. Value can be on or off
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
nic_ipspace
ipspace
IPSpace of an interface
rx_frames_per_sec
receive_frames_per_sec
Frames received per second
rx_frames
receive_frames
Frames received
rx_bytes_per_sec
receive_bytes_per_sec
Bytes received per second
rx_bytes
receive_bytes
Bytes received
rx_errors_per_min
receive_errors_per_min
Error received per minute
rx_errors
receive_errors
Error received
rx_discards_per_min
receive_discards_per_min
Discarded receiving frames per minute
rx_discards
receive_discards
rx_total_frames
receive_total_frames
Total frames received
rx_total_bytes
receive_total_bytes
Total bytes received
rx_total_errors
receive_total_errors
Total errors received
rx_total_discards
receive_total_discards
Total queue drop or discard frame received
rx_multi_broadcast
receive_multicast_broadcast
Multicast or broadcast frames received
rx_no_buffers
receive_no_buffers
No receiving buffer available counter
rx_non_primary_uc
receive_non_primary_unicast
Frames with non-primary unicast address received
rx_lro_segments
receive_lro_segments
LRO (Large Receive Offload) segments received
rx_lro_bytes
receive_lro_bytes
LRO (Large Receive Offload) bytes received
rx_lro6_segments
receive_lro6_segments
IPv6 frame LRO (Large Receive Offload) segments received
rx_lro6_bytes
receive_lro6_bytes
IPv6 frame LRO (Large Receive Offload) bytes received
rx_mcast_v6_solicit
receive_multicast_v6_solicit
IPv6 multicast received
rx_tag_drop
receive_tag_drop
Dropped frames with tag received
rx_vlan_tag_drop
receive_vlan_tag_drop
Dropped frames with tag on a VLAN received
rx_vlan_untag_drop
receive_vlan_untag_drop
Dropped frames without tag received
rx_vlan_forwards
receive_vlan_forwards
Frames received which are forwarded on the VLAN
rx_vlan_broadcasts
receive_vlan_broadcasts
Frames received which are broadcasted onto a VLAN
rx_vlan_unicasts
receive_vlan_unicasts
Frames received which are unicasted on the VLAN
tx_frames_per_sec
transmit_frames_per_sec
Frames sent per second
tx_frames
transmit_frames
Frames sent
tx_bytes_per_sec
transmit_bytes_per_sec
Bytes sent per second
tx_bytes
transmit_bytes
Bytes sent
tx_errors_per_min
transmit_errors_per_min
Error sent per minute
tx_errors
transmit_errors
Error sent
tx_discards_per_min
transmit_discards_per_min
Discarded frames sent per minute
tx_discards
transmit_discards
Discards frames sent
tx_total_frames
transmit_total_frames
Total frames sent
tx_total_bytes
transmit_total_bytes
Total bytes sent
tx_total_errors
transmit_total_errors
Total errors sent
tx_total_discards
transmit_total_discards
Total queue drops on sending
tx_multi_broadcast
transmit_multicast_broadcast
Total multicast/broadcast frames sent
tx_queue_overflows
transmit_queue_overflows
Sending queue overflows counter
tx_no_buffers
transmit_no_buffers
No sending buffers available count
tx_frames_queued
transmit_frames_queued
Sent frames queued
tx_buffer_coalesces (Deprecated)
transmit_buffer_coalesces
Sending coalesces buffers
tx_mtus_too_big
transmit_mtus_too_big
Oversized packets sent (MTUs too big)
tx_tso_segments
transmit_tso_segments
TSO (TCP Segmentation Offload) segments sent
tx_tso_bytes
transmit_tso_bytes
TSO (TCP Segmentation Offload) bytes sent
tx_tso6_segments
transmit_tso6_segments
IPv6 frame TSO (TCP Segmentation Offload) segments sent
tx_tso6_bytes
transmit_tso6_bytes
IPv6 frame TSO (TCP Segmentation Offload) bytes sent
tx_mcast_v6_solicit
transmit_multicast_v6_solicit
IPv6 multicast transmitted
hwassist
hwassist
HW offload capability of the interface
tx_ltm_fastp_calls (Deprecated)
transmit_ltm_fast_path_calls
LTM (LAN Topology Module) sending fast path call counter
tx_ltm_busy_calls (Deprecated)
transmit_ltm_busy_calls
LTM (LAN Topology Module) sending failed or busy call counter
tx_ltm_update_calls (Deprecated)
transmit_ltm_update_calls
LTM (LAN Topology Module) sending update call counter
tx_ltm_yield_calls (Deprecated)
transmit_ltm_yield_calls
LTM (LAN Topology Module) sending yield call counter
tx_ltm_total_calls (Deprecated)
transmit_ltm_total_calls
LTM (LAN Topology Module) sending call counter
total_bytes
total_bytes
Bytes received and sent
total_errors
total_errors
Error received and sent
rx_crc_errors
receive_crc_errors
CRC errors detected on received packets
rx_unsupported_op
receive_unsupported_op
Total number of unsupported MAC Control Opcode received in Ethernet MAC control
frame format field
rx_length_errors
receive_length_errors
Length errors detected on received packets
rx_runt_frames
receive_runt_frames
Very short frames received
rx_fragment
receive_fragment
Fragmented frames received
rx_long_frames
receive_long_frames
Very long frames received
rx_jabber
receive_jabber
Jabber frames received
rx_illegal_symbol
receive_illegal_symbol
Illegal symbol frames received
rx_error_symbol
receive_error_symbol
Error symbol frames received
rx_alignment_errors
receive_alignment_errors
Alignment errors detected on received packets
rx_bus_overruns
receive_bus_overruns
Bus overruns received
rx_xon
receive_xon
Xon frames received
rx_xoff
receive_xoff
Xoff frames received
rx_jumbo
receive_jumbo
Jumbo frames received
tx_hw_errors
transmit_hw_errors
Transmit errors reported by hardware
tx_link_down_drop
transmit_link_down_drop
Transmit packets dropped by hardware because the link was down
tx_cfg_up_down
transmit_config_up_down
Link down state changes
tx_bus_overruns
transmit_bus_overruns
Bus overruns sent
collisions
collisions
Collisions on CSMA interfaces
tx_max_collisions
transmit_max_collisions
Maximum collisions sent
tx_single_collisions
transmit_single_collisions
Single collisions sent
tx_multi_collisions
transmit_multiple_collisions
Multiple collisions sent
tx_late_collisions
transmit_late_collisions
Late collisions sent
tx_xon
transmit_xon
Transmitter on (XON) frames sent
tx_xoff
transmit_xoff
Transmitter Off (XOFF) frames sent
tx_jumbo
transmit_jumbo
Jumbo frames sent
link_up_to_downs
link_up_to_down
Number of link state change from UP to DOWN.
rss_itable_updates
rss_itable_updates
Number of hash table updates
rss_hash_errors
rss_hash_errors
Number of hash errors
rss_num_of_queues_used
Number of queues used in RSS
rss_matrix
rss_matrix
Matrix of RSS queue stats. The distribution of packet processing on each network
queue. Each queue will have Transmit/Receive frames/bytes counting and requeue
counting
rss_cg_stat
rss_cg_stat
RSS receive queue to CG queue mapping
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
