ONTAP performance counter mapping
svm_cifs
The svm_cifs table reports activity of the Common Internet File System Protocol subsystem. This is the Microsoft file-sharing protocol that evolved from the Server Message Block(SMB) application layer network protocol to connect PCs to Network Attached Storage(NAS) devices. This table supports SVM specific activity for SMB, SMB2, and SMB3 revisions of the CIFS protocol. The alias name for svm_cifs:node is svm_cifs_node.
Classic Object: cifs
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{node.name}:{instance_name}:{instance_uuid}
constituent
This represents the construction of a row ID field for a row from a single node.
{node.name}:{node.uuid}
node
This represents the construction of the row ID field in node combo object, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Node name
node_uuid
node.uuid
Node UUID
instance_name
name
Name of the CIFS instance
vserver_name
svm.name
SVM name
vserver_id
svm.id
SVM ID
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
cifs_ops
total_ops
Total number of CIFS operations
cifs_op_count
op_count
Array of select CIFS operation counts
cifs_op_pct
op_percent
Array of select CIFS operation counts as a percentage of total CIFS operations
cifs_latency
latency
Average latency for CIFS operations
cifs_latency_base
latency_base
Total observed CIFS operations to be used as a base counter for CIFS average
latency calculation
cifs_latency_hist
cifs_latency_histogram
Histogram of latency for CIFS operations
cifs_read_ops
total_read_ops
Total number of CIFS read operations
cifs_write_ops
total_write_ops
Total number of CIFS write operations
cifs_read_latency
average_read_latency
Average latency for CIFS read operations
cifs_write_latency
average_write_latency
Average latency for CIFS write operations
cifs_read_latency_hist
read_latency_histogram
Histogram of latency for CIFS read operations
cifs_write_latency_hist
write_latency_histogram
Histogram of latency for CIFS write operations
cifs_read_size_histo
read_size_histogram
Histogram of CIFS read sizes
cifs_write_size_histo
write_size_histogram
Histogram of CIFS write sizes
read_data
read_data
Rate of CIFS read data transfers per second.
write_data
write_data
Rate of CIFS write data transfers per second.
total_data
total_data
Rate of total CIFS data transfers per second.
commands_outstanding
Number of SMB and SMB2 commands in process
change_notifications_outstanding
Number of active change notifications over SMB and SMB2
connections
connections
Number of connections
outstanding_auth_requests
Number of outstanding authentication requests
established_sessions
Number of established SMB and SMB2 sessions
signed_sessions
signed_sessions
Number of signed SMB and SMB2 sessions.
connected_shares
connected_shares
Number of SMB and SMB2 share connections
open_files
open_files
Number of open files over SMB and SMB2
active_searches
active_searches
Number of active searches over SMB and SMB2
max_commands_outstanding
Maximum number of SMB and SMB2 commands in process at one time
max_change_notifications_outstanding
Maximum number of SMB and SMB2 change notifications pending at one time
max_connections
max_connections
Maximum number of connections achieved
max_outstanding_auth_requests
Maximum number of outstanding authentication requests
max_established_sessions
Maximum number of established SMB and SMB2 sessions achieved
max_connected_shares
Maximum number of SMB and SMB2 share connections achieved
max_open_files
max_open_files
Maximum number of open files over SMB and SMB2 achieved
max_active_searches
max_active_searches
Maximum number of active searches over SMB and SMB2 achieved
max_sessions_per_connection
Maximum number of SMB or SMB2 sessions multiplexed over a single connection
max_shares_per_session
Maximum number of share connections achieved within a single SMB or SMB2 session
max_open_files_per_share
Maximum number of open files achieved over a single share connection within a
handle_lease_ignored
Number of times a request for a handle lease was ignored because too many had
been granted to a single session.
max_searches_per_session
Maximum number of directory searches achieved over a single SMB or SMB2 session
max_same_tree_connect_per_session
max_same_tree_connections_per_session
Maximum number of CIFS tree connects achieved over the same share within a
single CIFS session. This counter will be set only when shares within a single
CIFS session exceeds the max_same_tree_connections_per_session configured value.
max_same_user_session_per_conn
max_same_user_sessions_per_connection
Maximum number of CIFS sessions achieved by the same user within a single TCP
connection. This counter will be set only when total number of session on a CIFS
connection exceeds the max_same_user_sessions_per_connection configured value.
max_opens_same_file_per_tree
Maximum number of existing opens achieved on the same file within a single CIFS
tree. This counter will be set only when number of opens on a CIFS tree exceeds
the max_opens_same_file_per_tree configured value.
max_watches_set_per_tree
Maximum number of watches, also known as 'change notifies,' achieved within a
single CIFS tree. This counter will be set only when number of watches on a CIFS
tree exceeds the max_watches_set_per_tree configured value.
auth_reject_too_many
Authentication refused after too many requests were made in rapid succession
open_reject_too_many
Open refused after too many requests were made by the same user to the same file
session_reject_too_many
Session refused after too many session requests for the same user for the same
client
watch_reject_too_many
Watch request, also known as 'change notify,' refused after too many watch
requests
tree_connect_reject_too_many
Tree connect request rejected after too many connects to same share on session
duplicate_session_disconnected
Detected and terminated a duplicate session
connection_idle_close
Detected and terminated an idle connection
session_idle_close
session_idle_close
Detected and terminated an idle session
conn_could_not_close_without_waiting
connections_could_not_close_without_waiting
Number of connections could not be closed right away
conn_closed_internally_unexpected
connections_closed_internally_unexpected
Number of connections closed unexpectedly because of internal error
conn_hung_cnt
hung_connections_count
Number of connections hung while closing
non_unicode_client_rejected
Rejected a connection attempt from a client that does not support Unicode
node_referral_local
node_referral.local
Number of clients that connected using a LIF hosted by the same node that hosts
the share root. Normally local access provides optimal performance.
node_referral_remote
node_referral.remote
Number of clients that connected using a LIF hosted by a node different from the
node that hosts the share root. Remote access may result in degraded
performance.
node_referral_issued
node_referral.issued
Number of clients that were issued a referral to the share root's node after the
client connected using a LIF hosted by a node different from the share root's
node.
node_referral_not_possible
node_referral.not_possible
Number of clients that were not issued a referral to the node hosting the share
root after connecting using a LIF hosted by a node different from the share
root's node. No active data LIF for the share root's node was found
reconnection_requests_total
reconnection_requests.total
Number of clients who issued a CIFS reconnect request
reconnection_requests_failed
reconnection_requests.failed
Number of CIFS reconnect requests which failed
persistent_opens
persistent_opens
Number of CIFS persistent open requests made by clients
durable_opens
durable_opens
Number of CIFS durable open requests made by clients
optimized_smb2_opens
Number of SMB2 open requests which used SPINNP_LOOKUP instead of SPINNP_OPEN
lock_reconstruction
lock_reconstruction
Number of times lock reconstruction status has been encountered while processing
CIFS requests from clients
server_side_close_conn
server_side_close_connection
Number of times a decision has been made to initiate server-side closure of a
client connection
continuously_available_connections
Number of connections from CA-capable clients to continuously available shares
privileged_lock_test_req
privileged_lock.test_requests
Number of Lock Test requests from the client
privileged_lock_req
privileged_lock.requests
Number of Lock Requests from the client
nbt_session_requests
nbt_session.requests
Number of NetBIOS session requests
nbt_session_keepalives
nbt_session.keep_alives
Number of NetBIOS session keep-alives
nameserver_query_requests
name_server.query_requests
Number of incoming nameserver query requests
nameserver_query_request_matches
name_server.query_request_matches
Number of incoming nameserver query requests that matched
nameserver_registration_requests
name_server.registration_requests
Number of incoming nameserver registration requests
nameserver_registration_request_matches
name_server.registration_request_matches
Number of incoming nameserver registration requests that matched
path_based_ops
path_based_ops
Number of SMB and SMB2 path-based commands
avg_directory_depth
average_directory_depth
Average number of directories crossed by SMB and SMB2 path-based commands
max_directory_depth
max_directory_depth
Maximum number of directories crossed by SMB and SMB2 path-based commands
avg_junction_depth
average_junction_depth
Average number of junctions crossed by SMB and SMB2 path-based commands
max_junction_depth
max_junction_depth
Maximum number of junctions crossed by SMB and SMB2 path-based commands
path_cache_entries
path_cache.entries
Number of entries in the path cache
path_cache_max_entries
path_cache.max_entries
Maximum number of entries in the path cache
path_cache_requests
path_cache.requests
Number of path cache requests
path_cache_hits
path_cache.hits
Number of path cache hits
path_cache_misses
path_cache.misses
Number of path cache misses
path_cache_latency
path_cache.average_latency
Average latency for a path cache request (hit or miss)
path_cache_hit_latency
path_cache.average_hit_latency
Average latency for a path cache hit
path_cache_hit_latency_histogram
path_cache.hit_latency_histogram
Latency histogram for path cache hits
path_cache_miss_latency
path_cache.average_miss_latency
Average latency for a path cache miss
path_cache_miss_latency_histogram
path_cache.miss_latency_histogram
Latency histogram for path cache misses
file_handle_cache_entries
file_handle_cache.entries
Number of entries in the file handle cache
file_handle_cache_max_entries
file_handle.cache_max_entries
Maximum number of entries in the file handle cache
file_handle_cache_requests
file_handle_cache.requests
Number of file handle cache requests
file_handle_cache_hits
file_handle_cache.hits
Number of file handle cache hits
file_handle_cache_misses
file_handle_cache.misses
Number of file handle cache misses
file_handle_cache_latency
file_handle_cache.average_latency
Average latency for a file handle cache request (hit or miss)
file_handle_cache_hit_latency
file_handle_cache.average_hit_latency
Average latency for a file handle cache hit
file_handle_cache_hit_latency_histogram
file_handle_cache.hit_latency_histogram
Latency histogram for file handle cache hits
file_handle_cache_miss_latency
file_handle_cache.average_miss_latency
Average latency for a file handle cache miss
file_handle_cache_miss_latency_histogram
file_handle_cache.miss_latency_histogram
Latency histogram for file handle cache misses
flow_control_connections
flow_control.connections
Total number of connections that have been placed into flow control
flow_control_back_to_back
flow_control.back_to_back
Total number of connections that have been released from flow control only to be
put back into flow control before they get a chance to run
flow_control_max_queue_depth
flow_control.max_queue_depth
Maximum queue depth for flow control connection queues
flow_control_latency_hist
flow_control.latency_histogram
Histogram of flow control caused latency for CIFS connections
flexgroup_lookup_redrive
flexgroup_lookup.redrive
Total number of times a CIFS lookup has been redirected by the FlexGroup layer
flexgroup_open_redrive
flexgroup_open.redrive
Total number of times a CIFS file or directory open or creation has been
flexgroup_lookup_multiple_redrive
flexgroup_lookup.multiple_redrive
Total number of times a single CIFS lookup operation has been redirected
multiple times in a row
flexgroup_open_multiple_redrive
flexgroup_open.multiple_redrive
Total number of times a single CIFS file or directory open or creation operation
has been redirected multiple times in a row
flexgroup_msid_cache_hit
flexgroup_msid_cache.hits
Total number of times we have found a FlexGroup target MSID in the CIFS MSID
path cache
flexgroup_msid_cache_max_entries
flexgroup_msid_cache.max_entries
Maximum number of entries stored in any CIFS MSID path cache
flexgroup_msid_cache_max_depth
flexgroup_msid_cache.max_depth
Maximum path depth stored in any CIFS MSID path cache
component_cache
component_cache
Array of component cache stats
branchcache_hash_fetch_fail
branch_cache.hash_fetch_fail
Total number of times a request to fetch hash data failed. These are failures
when attempting to read existing hash data. It does not include attempts to
fetch hash data that has not yet been generated.
branchcache_missing_hash_bytes
branch_cache.missing_hash_bytes
Total number of bytes of data that had to be read by the client because the hash
for that content was not available on the server.
branchcache_hash_fetch_ok
branch_cache.hash_fetch_ok
Total number of times a request to fetch hash data succeeded.
branchcache_hash_sent_bytes
branch_cache.hash_sent_bytes
Total number of bytes sent to clients requesting hashes.
copyoffload_directcopy_read_request
Total number of Copy Offload Direct-Copy Read requests.
ioctl_fsctl_set_zero_data_unaligned_request
Total number of FSCTL_SET_ZERO_DATA requests not aligned to block-boundaries.
sd_max_ace_count
security_descriptor.max_ace_count
Maximum number of ACEs received in a security descriptor.
sd_max_ace_size
security_descriptor.max_ace_size
Maximum size of ACEs received in a security descriptor.
cred_max_user_claims
credential.max_user_claims
Maximum size of user claims in CIFS credentials
cred_max_device_claims
credential.max_device_claims
Maximum size of device claims in CIFS credentials
cred_max_device_groups
credential.max_device_groups
Maximum number of groups a device is a member of.
cred_build_req
credential.build_requests
Number of SpinNp Credential Build Requests for CIFS.
cred_avg_win_groups
credential.average_win_groups
Average number of windows groups any user is a member of.
cred_max_win_groups
credential.max_win_groups
Maximum number of windows groups any user is a member of.
cred_avg_unix_groups
credential.average_unix_groups
Average number of UNIX groups any user is a member of.
cred_max_unix_groups
credential.max_unix_groups
Maximum number of UNIX groups any user is a member of.
cred_avg_total_groups
credential.average_total_groups
Average number of total groups any user is a member of.
cred_max_total_groups
credential.max_total_groups
Maximum number of total groups any user is a member of.
cred_max_size_bytes
credential.max_size
Maximum size (in bytes) of the SpinNp credential for any CIFS user.
cred_avg_size_bytes
credential.average_size
Average size (in bytes) of the SpinNp credential for any CIFS user.
smb1_connections_count
Current number of SMB1 connections.
total_smb1_connections_count
Total number of SMB1 connections.
smb2_connections_count
Current number of SMB2.0 connections.
encrypted_sessions
encrypted_sessions
Number of encrypted SMB3 sessions.
encrypted_share_connections
Number of encrypted share connections. This is the number of encrypted shares on
which a tree connect has happened.
rejected_unencrypted_sessions
Number of session setups rejected due to the lack of client encryption
capability.
rejected_unencrypted_shares
Number of share mappings rejected due to the lack of client encryption
capability.
total_smb2_connections_count
Total number of SMB2.0 connections.
smb2_1_connections_count
Current number of SMB2.1 connections.
total_smb2_1_connections_count
Total number of SMB2.1 connections.
smb3_connections_count
Current number of SMB3 connections.
total_smb3_connections_count
Total number of SMB3 connections.
smb3_1_connections_count
Current number of SMB3.1 connections.
total_smb3_1_connections_count
Total number of SMB3.1 connections.
extended_dfs_referral_reqs
Total number of extended DFS referrals (FSCTL_DFS_GET_REFERRALS_EX requests).
no_version_negotiated
no_version_negotiated_requests
Total number of negotiate requests that were dropped because no mutually
supported SMB version is found.
widelink_request
widelink_requests
Total number of widelink encountered while resolving symlinks.
homedir_share_request
homedir_share_requests
Total number of Tree Connect requests for a home directory share.
export_policy_request
export_policy_requests
Total number of requests using an export policy.
access_based_enumeration
access_based_enumeration_requests
Total number of requests using Access Based Enumeration.
optimized_smb2_open
optimized_smb2_open_requests
Total number of optimized SMB2 open requests.
null_user_session
null_user_sessions
Total number of NULL or Anonymous user sessions.
guest_user_session
guest_user_sessions
Total number of Guest user sessions.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
op_count
For each of the new labels in this array, the values have been changed to
be lower case and any other non-alphanumeric characters have been replaced
by an underscore.
op_percent
by an underscore.
component_cache
be lower case and white spaces have been replaced by underscores.
Table Aliases
This section describes aliases for aggregated tables.
Classic Object Alias
svm_cifs:node
svm_cifs_node
