ONTAP performance counter mapping
qos_resource
The resource CM table provides CPU and aggregate resource utilization information.
Classic Object: resource
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
parent_resource
parent_resource
The parent of the resource.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
busy_percent
busy_percent
The percent of the resource that is used.
num_instances
num_instances
The number of instances (processors, disks, and so on) in the resource.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
