ONTAP performance counter mapping
exec_context
These counters are used to monitor the performance of the exec context manager in the nblade.
Classic Object: exec_ctx
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Node Name.
node_uuid
node.uuid
Node UUID.
instance_name
name
Name of the exec context.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
current_free_exec
current_free_exec
Current number of available execution contexts.
preallocated
preallocated
Total number of pre-allocated execution contexts.
alloc_attempts
allocation_attempts
Exec context allocation attempts.
alloc_failures
allocation_failures
Exec context allocation failures.
long_running
long_running
Current long running exec contexts.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
current_free_exec
The current number of available execution contexts.
allocation_attempts
The number of execution context allocation attempts.
allocation_failures
The number of execution context allocation failures.
long_running
The current number of long running execution contexts.
Table Aliases
This section describes aliases for aggregated tables.
