Delete the CIFS domain preferred DC configuration for an SVM and domain
Deletes the CIFS domain preferred DC configuration for a specified SVM and domain. Use this operation to remove a preferred domain controller setup when it is no longer needed.
HTTP method and endpoint
DELETE /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
Introduced in
ONTAP 9.10
Usage notes
Deletes the CIFS domain preferred DC configuration of the specified SVM and domain.
Related ONTAP commands
vserver cifs domain preferred-dc delete
fqdn |
string |
path |
True |
Fully Qualified Domain Name |
server_ip |
string |
path |
True |
Domain Controller IP address |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655507 |
Failed to remove preferred-dc. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
