REST API reference
Remove an NVMe subsystem
Removes an NVMe subsystem, eliminating its configuration from the system. Use this operation when you need to decommission or reconfigure NVMe subsystems within your storage environment.
HTTP method and endpoint
DELETE /protocols/nvme/subsystems/{uuid}
Introduced in
ONTAP 9.6
  • vserver nvme subsystem delete
uuid
string
path
True
The unique identifier of the NVMe subsystem.
allow_delete_while_mapped
boolean
query
False
Allows for the deletion of a mapped NVMe subsystem.
allow_delete_with_hosts
boolean
query
False
Allows for the deletion of an NVMe subsystem with NVMe hosts.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
72090001
The NVMe subsystem does not exist.
72090023
The NVMe subsystem contains one or more mapped namespaces. Use the allow_delete_while_mapped query parameter to delete an NVMe subsystem with mapped NVMe namespaces.
72090024
The NVMe subsystem contains one or more NVMe hosts. Use the allow_delete_with_hosts query parameter to delete an NVMe subsystem with NVMe hosts.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
