REST API reference
Retrieve DR group information using the DR group ID
Retrieves information about a specific DR group by specifying its ID. This helps you access detailed configurations and status of the DR group for management and troubleshooting purposes.
HTTP method and endpoint
GET /cluster/metrocluster/dr-groups/{id}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the DR group information specified by the DR group id.
id
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
dr_pairs
array[dr_pair]
id
integer
DR Group ID
partner_cluster
partner_cluster
Partner cluster information.
      "href": "/api/resourcelink"
  "dr_pairs": [
      "node": {
        "name": "node1",
      "partner": {
        "name": "node1",
  "id": 0,
  "partner_cluster": {
    "name": "cluster1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
node
Local node of the DR Group.
_links
_links
name
string
uuid
string
partner
Partner node of the DR Group.
_links
_links
name
string
uuid
string
dr_pair
node
node
partner
partner
ipv4_interface
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
l3_config
ipv4_interface
ipv4_interface
node
Node information
_links
_links
name
string
uuid
string
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config
l3_config
name
string
Port name
node
node
Node information
uuid
string
Port UUID
vlan_id
integer
VLAN ID
partner_cluster
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
