Retrieve the Vscan On-Demand configuration for an SVM
Retrieves the Vscan On-Demand configuration for a specific SVM to understand its virus scanning settings and policies.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/on-demand-policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the Vscan On-Demand configuration of an SVM.
Related ONTAP commands
vserver vscan on-demand-task show
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
log_path |
string |
The path from the Vserver root where the task report is created. |
name |
string |
On-Demand task name |
scan_paths |
array[string] |
List of paths that need to be scanned. |
schedule |
Schedule of the task. |
scope |
svm |
"log_path": "/vol0/report_dir",
"name": "task-1",
"scan_paths": [
"/vol1/",
"/vol2/cifs/"
"schedule": {
"href": "/api/resourcelink"
"name": "weekly",
"scope": {
"exclude_extensions": [
"mp3",
"mp4"
"exclude_paths": [
"/vol1/cold-files/",
"/vol1/cifs/names"
"include_extensions": [
"vmdk",
"mp*"
"max_file_size": 10737418240
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
scope
exclude_extensions |
array[string] |
List of file extensions for which scanning is not performed. |
exclude_paths |
array[string] |
List of file paths for which scanning must not be performed. |
include_extensions |
array[string] |
List of file extensions to be scanned. |
max_file_size |
integer |
Maximum file size, in bytes, allowed for scanning. |
scan_without_extension |
boolean |
Specifies whether or not files without any extension can be scanned. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
