REST API reference
Retrieve SVMs and SVM properties
Retrieves Storage Virtual Machines (SVMs) and their properties, including protocol configurations like CIFS and NFS, export policies, and network services. Use this to access detailed protocol and service settings for efficient management of your storage resources.
HTTP method and endpoint
GET /svm/svms
Introduced in
ONTAP 9.6
Usage notes
Retrieves a list of SVMs and individual SVM properties. This includes protocol configurations such as CIFS and NFS, export policies, name service configurations, and network services.
Important notes
  • The SVM object includes a large set of fields and can be expensive to retrieve. Use this API to list the collection of SVMs, and to retrieve only the full details of individual SVMs as needed.
  • It is not recommended to create or delete more than five SVMs in parallel.
  • REST APIs only expose a data SVM as an SVM.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • snapmirror.*
  • vserver show
  1. Retrieves a list of SVMs in the cluster sorted by name
  GET "/api/svm/svms?order_by=name"
  1. Retrieves a list of SVMs in the cluster that have the NFS protocol enabled
  GET "/api/svm/svms?nfs.enabled=true"
  1. Retrieves a list of SVMs in the cluster that have the CIFS protocol enabled
  GET "/api/svm/svms?cifs.enabled=true"
  1. Retrieves a list of SVMs in the cluster that have the S3 protocol enabled
  GET "/api/svm/svms?s3.enabled=true"
5 Retrieves a list of SVMs in the cluster that have the FCP protocol allowed
  GET "/api/svm/svms?fcp.allowed=true"
  1. Retrieves a list of SVMs in the cluster that have the CIFS protocol allowed
  GET "/api/svm/svms?cifs.allowed=true"
  1. Retrieves a list of SVMs in the cluster where the NDMP protocol is specified as allowed
  GET "/api/svm/svms?ndmp.allowed=true"
Learn more
nis.enabled
boolean
query
False
Filter by nis.enabled
nis.servers
string
query
False
Filter by nis.servers
nis.domain
string
query
False
Filter by nis.domain
nvme.allowed
boolean
query
False
Filter by nvme.allowed
  • Introduced in: 9.9
nvme.enabled
boolean
query
False
Filter by nvme.enabled
language
string
query
False
Filter by language
nfs.allowed
boolean
query
False
Filter by nfs.allowed
nfs.enabled
boolean
query
False
Filter by nfs.enabled
comment
string
query
False
Filter by comment
aggregates.name
string
query
False
Filter by aggregates.name
aggregates.uuid
string
query
False
Filter by aggregates.uuid
subtype
string
query
False
Filter by subtype
dns.servers
string
query
False
Filter by dns.servers
dns.domains
string
query
False
Filter by dns.domains
fcp.allowed
boolean
query
False
Filter by fcp.allowed
fcp.enabled
boolean
query
False
Filter by fcp.enabled
iscsi.allowed
boolean
query
False
Filter by iscsi.allowed
iscsi.enabled
boolean
query
False
Filter by iscsi.enabled
name
string
query
False
Filter by name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
ipspace.name
string
query
False
Filter by ipspace.name
ldap.base_dn
string
query
False
Filter by ldap.base_dn
ldap.servers
string
query
False
Filter by ldap.servers
ldap.enabled
boolean
query
False
Filter by ldap.enabled
ldap.bind_dn
string
query
False
Filter by ldap.bind_dn
ldap.ad_domain
string
query
False
Filter by ldap.ad_domain
uuid
string
query
False
Filter by uuid
cifs.name
string
query
False
Filter by cifs.name
cifs.ad_domain.fqdn
string
query
False
Filter by cifs.ad_domain.fqdn
cifs.ad_domain.organizational_unit
string
query
False
Filter by cifs.ad_domain.organizational_unit
cifs.allowed
boolean
query
False
Filter by cifs.allowed
cifs.enabled
boolean
query
False
Filter by cifs.enabled
s3.name
string
query
False
Filter by s3.name
  • Introduced in: 9.7
s3.enabled
boolean
query
False
Filter by s3.enabled
ndmp.allowed
boolean
query
False
Filter by ndmp.allowed
  • Introduced in: 9.10
nsswitch.netgroup
string
query
False
Filter by nsswitch.netgroup
nsswitch.group
string
query
False
Filter by nsswitch.group
nsswitch.hosts
string
query
False
Filter by nsswitch.hosts
nsswitch.namemap
string
query
False
Filter by nsswitch.namemap
nsswitch.passwd
string
query
False
Filter by nsswitch.passwd
qos_policy.name
string
query
False
Filter qos_policy.name
qos_policy.uuid
string
query
False
Filter qos_policy.uuid
max_volumes
string
query
False
Filter max_volumes
fc_interfaces.name
string
query
False
Filter by fc_interfaces.name
fc_interfaces.data_protocol
string
query
False
Filter by fc_interfaces.data_protocol
snapshot_policy.uuid
string
query
False
Filter by snapshot_policy.uuid
snapshot_policy.name
string
query
False
Filter by snapshot_policy.name
state
string
query
False
Filter by state
certificate.uuid
string
query
False
Filter by certificate.uuid
anti_ransomware_default_volume_state
string
query
False
Filter by anti_ransomware_default_volume_state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[svm]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "aggregates": [
          "name": "aggr1",
      "anti_ransomware_default_volume_state": "string",
      "certificate": {
        "name": "cert1",
      "cifs": {
        "ad_domain": {
          "fqdn": "example.com",
          "organizational_unit": "string"
        "name": "CIFS1"
      "comment": "string",
      "dns": {
        "domains": [
          "example.com",
          "example2.example3.com"
        "servers": [
          "10.224.65.20",
          "2001:db08:a0b:12f0::1"
      "fc_interfaces": [
          "data_protocol": "string",
          "name": "lif1",
      "fcp": {
      "ip_interfaces": [
          "ip": {
            "address": "10.10.10.7"
          "name": "lif1",
          "services": [
            "data_nfs"
      "ipspace": {
        "name": "exchange",
      "iscsi": {
      "language": "c.utf_8",
      "ldap": {
        "ad_domain": "string",
        "base_dn": "string",
        "bind_dn": "string",
        "servers": [
          "string"
      "max_volumes": "string",
      "name": "svm1",
      "nfs": {
      "nis": {
        "domain": "string",
        "servers": [
          "string"
      "nsswitch": {
        "group": [
          "string"
        "hosts": [
          "string"
        "namemap": [
          "string"
        "netgroup": [
          "string"
        "passwd": [
          "string"
      "nvme": {
      "qos_policy": {
        "max_throughput_iops": 10000,
        "max_throughput_mbps": 500,
        "min_throughput_iops": 2000,
        "min_throughput_mbps": 500,
        "name": "performance",
      "s3": {
        "certificate": {
          "name": "cert1",
        "name": "s3-server-1"
      "snapmirror": {
        "protected_volumes_count": 0
      "snapshot_policy": {
        "name": "default",
      "state": "running",
      "subtype": "string",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
aggregates
Aggregate
_links
_links
name
string
uuid
string
certificate
Support for this field will be removed in a future release. Please use /svm/svms/{svm.uuid}/web for this field. Certificate for incoming TLS connection requests.
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
ad_domain
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server.
cifs
_links
_links
ad_domain
ad_domain
allowed
boolean
If this is set to true, an SVM administrator can manage the CIFS service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the CIFS service.
name
string
The NetBIOS name of the CIFS server.
dns
_links
_links
domains
array[string]
A list of DNS domains. Domain names have the following requirements:
  • The name must contain only the following characters: A through Z, a through z, 0 through 9, ".", "-" or "_".
  • The first character of each label, delimited by ".", must be one of the following characters: A through Z or a through z or 0 through 9.
  • The last character of each label, delimited by ".", must be one of the following characters: A through Z, a through z, or 0 through 9.
  • The top level domain must contain only the following characters: A through Z, a through z.
  • The system reserves the following names:"all", "local", and "localhost".
servers
array[string]
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses.
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
fc_port_reference
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links
_links
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
location
The location of the Fibre Channel interface is defined by the location of its port.
port
fc_port_reference
fc_interface_svm
_links
_links
data_protocol
string
The data protocol for which the Fibre Channel interface is configured.
name
string
The name of the Fibre Channel interface.
uuid
string
The unique identifier of the Fibre Channel interface.
fcp
_links
_links
allowed
boolean
If this is set to true, an SVM administrator can manage the FCP service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the FCP service.
ip
IP information
address
string
broadcast_domain
Broadcast domain UUID along with a readable name.
_links
_links
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
home_node
_links
_links
name
string
uuid
string
location
Home_node is optional.
broadcast_domain
broadcast_domain
home_node
home_node
ip_interface_svm
Interface parameters. Name and home_node are optional.
_links
_links
ip
ip
IP information
name
string
The name of the interface (optional).
services
array[string]
The services associated with the interface.
uuid
string
The UUID that uniquely identifies the interface.
ipspace
Either the UUID or name may be supplied on input.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
iscsi
_links
_links
allowed
boolean
If this is set to true, an SVM administrator can manage the iSCSI service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the ISCSI service.
ldap
ad_domain
string
This parameter specifies the name of the Active Directory domain used to discover LDAP servers for use by this client. This is mutually exclusive with servers during POST.
base_dn
string
Specifies the default base DN for all searches.
bind_dn
string
Specifies the user that binds to the LDAP servers. SVM API supports anonymous binding. For Simple and SASL LDAP binding, use the LDAP API endpoint.
enabled
boolean
Enable LDAP? Setting to true creates a configuration if not already created.
servers
array[string]
ndmp
allowed
boolean
If this is set to true, an SVM administrator can manage the NDMP service. If it is false, only the cluster administrator can manage the service.
nfs
_links
_links
allowed
boolean
If this is set to true, an SVM administrator can manage the NFS service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the NFS service.
nis
_links
_links
domain
string
The NIS domain to which this configuration belongs.
enabled
boolean
Enable NIS? Setting to true creates a configuration if not already created.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
nsswitch
Name service switch configuration
group
array[string]
Group sources
hosts
array[string]
Host sources
namemap
array[string]
NameMap sources
netgroup
array[string]
NetGroup sources
passwd
array[string]
Password sources
nvme
_links
_links
allowed
boolean
If this is set to true, an SVM administrator can manage the NVMe service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the NVMe service.
qos_policy
This optionally specifies which QoS policy group to apply to the Vserver. This policy group defines measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated.
_links
_links
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
ip_info
IP information
address
string
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
network_route_for_svm
destination
ip_info
IP information
gateway
string
The IP address of the gateway router leading to the destination.
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
s3
_links
_links
certificate
certificate
enabled
boolean
Specifies whether or not to enable S3. Setting this value to true creates a service if one is not yet created.
is_http_enabled
boolean
Specifies whether HTTP is enabled on the S3 server. By default, HTTP is disabled on the S3 server.
is_https_enabled
boolean
Specifies whether HTTPS is enabled on the S3 server. By default, HTTPS is enabled on the S3 server.
name
string
Specifies the name of the S3 server. A server name length can range from 1 to 253 characters and can only contain the following combination of characters 0-9, A-Z, a-z, ".", and "-".
port
integer
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80.
secure_port
integer
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443.
snapmirror
Specifies attributes for SVM DR protection.
is_protected
boolean
Specifies whether the SVM is a SnapMirror source SVM, using SnapMirror to protect its data.
integer
Specifies the number of SVM DR protected volumes in the SVM.
snapshot_policy
This is a reference to the Snapshot copy policy.
_links
_links
name
string
uuid
string
svm
_links
_links
aggregates
array[aggregates]
List of allowed aggregates for SVM volumes. An administrator is allowed to create volumes on these aggregates.
aggregates_delegated
boolean
This property is true when the administrator has delegated the aggregates for the SVM volumes.
string
Specifies the default Anti-ransomware state of the volumes in the SVM. Default "anti_ransomware_default_volume_state" property is disabled for POST operation. If this value is "disabled", Anti-ransomware protection is disabled by default on the new volumes that are created in the SVM. If this value is "dry_run", Anti-ransomware protection is in learning mode by default on the new volumes that are created in the SVM. When the Anti-ransomware license is not present, this property is ignored and volumes will be created with the "disabled" state.
certificate
certificate
cifs
cifs
comment
string
Comment
dns
dns
fc_interfaces
array[fc_interface_svm]
FC Interface for the SVM
fcp
fcp
ip_interfaces
array[ip_interface_svm]
IP interfaces for the SVM
ipspace
ipspace
iscsi
iscsi
language
string
Default volume language code. UTF-8 encoded languages are valid in POST or PATCH. Non UTF-8 language encodings are for backward compatibility and are not valid input for POST and PATCH requests.
ldap
ldap
max_volumes
string
This property is used by cluster administrator to specify the limit on maximum number of volumes allowed in the SVM. The value can be either the string "unlimited" or a number.
name
string
The name of the SVM.
ndmp
ndmp
nfs
nfs
nis
nis
nsswitch
nsswitch
nvme
nvme
qos_policy
qos_policy
s3
s3
snapmirror
snapmirror
snapshot_policy
snapshot_policy
state
string
SVM State
subtype
string
SVM subtype. The SVM subtype sync_destination is created automatically when an SVM of subtype sync_source is created on the source MetroCluster cluster. A POST request with sync_destination as SVM subtype is invalid.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
