REST API reference
Manage BGP peer groups
Manage BGP peer groups to configure and oversee BGP sessions between local interfaces and peer routers within your cluster. Use these endpoints to create, retrieve, update, and delete BGP peer groups, facilitating efficient network routing and management.
Overview
The following operations are supported:
  • Creation: POST network/ip/bgp/peer-groups
  • Collection Get: GET network/ip/bgp/peer-groups
  • Instance Get: GET network/ip/bgp/peer-groups/{uuid}
  • Instance Patch: PATCH network/ip/bgp/peer-groups/{uuid}
  • Instance Delete: DELETE network/ip/bgp/peer-groups/{uuid}
Retrieving network BGP sessions information
The IP BGP peer-groups GET API retrieves and displays relevant information pertaining to the BGP peer-groups configured in the cluster. The response can contain a list of multiple BGP peer-groups or a specific peer-group. Each BGP peer-group represents a BGP session configured between a local interface and a peer router.
Retrieving all BGP peer-groups in the cluster
The following example shows the list of all BGP peer-groups configured in a cluster.
# The API:
/api/network/ip/bgp/peer-groups
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/bgp/peer-groups" -H "accept: application/hal+json"
# The response:
"records": [
    "uuid": "5f22ae9d-87b2-11e9-a3a6-005056bb81a4",
    "name": "pg1",
        "href": "/api/network/ip/bgp/peer-groups/5f22ae9d-87b2-11e9-a3a6-005056bb81a4"
    "uuid": "5fd08be3-87b2-11e9-952f-005056bb2170",
    "name": "pg2",
        "href": "/api/network/ip/bgp/peer-groups/5fd08be3-87b2-11e9-952f-005056bb2170"
"num_records": 2,
    "href": "/api/network/ip/bgp/peer-groups"
Retrieving a specific BGP peer-group
The following example shows the response when a specific BGP peer-group is requested. The system returns an error when there is no peer-group with the requested UUID.
# The API:
/api/network/ip/bgp/peer-groups/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/bgp/peer-groups/5fd08be3-87b2-11e9-952f-005056bb2170" -H "accept: application/hal+json"
# The response:
"name": "pg2",
"ipspace": {
  "uuid": "84fd3375-879a-11e9-a3a6-005056bb81a4",
  "name": "Default",
      "href": "/api/network/ipspaces/84fd3375-879a-11e9-a3a6-005056bb81a4"
"local": {
  "interface": {
    "uuid": "5e76a305-87b2-11e9-952f-005056bb2170",
    "name": "bgp2",
    "ip": {
      "address": "10.10.10.2"
  "port": {
    "uuid": "f8ff73de-879a-11e9-952f-005056bb2170",
    "name": "e0h",
    "node": {
      "name": "node1"
"peer": {
  "address": "10.10.10.1",
  "asn": 65501
"state": "up",
Retrieving specific fields and limiting the output using filters
The following example shows the response when a filter is applied (location.port.node.name=node1) and only certain fields are requested. Filtered fields are in the output in addition to the default fields and requested fields.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/bgp/peer-groups?local.port.node.name=node1&fields=local.interface.ip,peer" -H "accept: application/hal+json"
# The response:
"records": [
    "name": "pg1",
    "local": {
      "interface": {
        "ip": {
      "port": {
        "node": {
          "name": "node1"
    "peer": {
      "address": "10.10.10.2",
      "asn": 65501
"num_records": 1,
    "href": "/api/network/ip/bgp/peer-groups?local.port.node.name=node1&fields=local.interface.ip,peer"
Creating a BGP peer-group
The BGP peer-group POST API is used to create a peer-group as shown in the following examples.
Creating a BGP peer-group with an existing interface
The following example shows how to create a BGP peer-group between an existing interface "bgp1" and peer router with the address "10.10.10.10". The local interface "bgp1" needs to support the management-bgp service, otherwise the system returns an error.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/network/ip/bgp/peer-groups?return_records=true" -d'{"name": "newPg", "ipspace.name":"Default", "local.interface.name": "bgp1", "peer.address":"10.10.10.10"}'
# The response:
"num_records": 1,
"records": [
    "uuid": "e3faacc6-87cb-11e9-a3a6-005056bb81a4",
    "name": "newPg",
    "ipspace": {
      "name": "Default"
    "local": {
      "interface": {
        "name": "bgp1"
    "peer": {
      "address": "10.10.10.10"
        "href": "/api/network/ip/bgp/peer-groups/e3faacc6-87cb-11e9-a3a6-005056bb81a4"
Creating a BGP peer-group and provisioning a new local interface
The following example shows how to create a BGP peer-group with any local interface. If the local interface doesn't exist, the system will create it first before creating the peer-group.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/network/ip/bgp/peer-groups?return_records=true" -d'{"name": "newPg1", "ipspace.name":"Default", "local": {"interface": {"name": "newlif"}, "ip": {"address": "9.9.9.9", "netmask": "24"}, "port": {"name": "e0f", "node": {"name": "node1"}}}, "peer.address":"10.10.10.10"}'
# The response:
"num_records": 1,
"records": [
    "uuid": "c292f069-8872-11e9-a3a6-005056bb81a4",
    "name": "newPg1",
    "ipspace": {
      "name": "Default"
    "local": {
      "interface": {
        "name": "newlif"
      "port": {
        "name": "e0f",
        "node": {
          "name": "node1"
    "peer": {
        "href": "/api/network/ip/bgp/peer-groups/c292f069-8872-11e9-a3a6-005056bb81a4"
Updating BGP peer-groups
The BGP peer-groups PATCH API is used to update attributes of a peer-group.
Updating the peer router address
The following example shows how the PATCH request changes the peer router IP address.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/network/ip/bgp/peer-groups/80d271c9-1f43-11e9-803e-005056a7646a" -H "accept: application/hal+json" -d '{"peer.address": "10.10.10.20" }'
Updating the peer-group to a new name
The following example shows how the PATCH request renames the peer-group.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/network/ip/bgp/peer-groups/80d271c9-1f43-11e9-803e-005056a7646a" -H "accept: application/hal+json" -d '{"name": "NewName"}'
Deleting BGP peer-groups
The BGP peer-groups DELETE API is used to delete an BGP peer-group.
Example
Deleting a BGP peer-group
The following DELETE request deletes a BGP peer-group.
# The API:
/api/network/ip/bgp/peer-group/{uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/network/ip/bgp/peer-groups/80d271c9-1f43-11e9-803e-005056a7646a"
