Manage core dumps
Retrieve and manage core dumps within the cluster using these endpoints. Access lists of core dumps, obtain specific core dump details, or delete core dumps as needed.
Overview
The core dump GET API retrieves all of the core dumps on the cluster or a node. The core dump DELETE API deletes a specified core dump. Some fields are only populated for core dump type "kernel". Refer to the model for further information. Fields will not be displayed if they are not populated. A core can be deleted even if the core is in the process of being saved.
1) Retrieving a list of core dumps from the cluster
The following example returns a list of core dumps on the cluster:
# The API:
/api/support/coredump/coredumps
# The call:
curl -X GET "https://<mgmt-ip>/api/support/coredump/coredumps" -H "accept: application/hal+json"
# The response:
"records": [
"node": {
"uuid": "227683c1-e9c7-11eb-b995-005056bbbfb3",
"name": "node2",
"href": "/api/cluster/nodes/227683c1-e9c7-11eb-b995-005056bbbfb3"
"type": "kernel",
"name": "core.4136886422.2021-07-21.20_20_53.nz",
"href": "/api/support/coredump/coredumps/227683c1-e9c7-11eb-b995-005056bbbfb3/core.4136886422.2021-07-21.20_20_53.nz"
"node": {
"name": "node2",
"type": "application",
"name": "mlogd.968.4136886422.2021-07-22.01_10_01.ucore.bz2",
"href": "/api/support/coredump/coredumps/227683c1-e9c7-11eb-b995-005056bbbfb3/mlogd.968.4136886422.2021-07-22.01_10_01.ucore.bz2"
"node": {
"uuid": "d583d44e-e9c6-11eb-a270-005056bb47f9",
"name": "node1",
"href": "/api/cluster/nodes/d583d44e-e9c6-11eb-a270-005056bb47f9"
"type": "kernel",
"name": "core.4136886421.2021-07-21.17_57_02.nz",
"href": "/api/support/coredump/coredumps/d583d44e-e9c6-11eb-a270-005056bb47f9/core.4136886421.2021-07-21.17_57_02.nz"
"node": {
"name": "node1",
"name": "mlogd.979.4136886421.2021-07-22.01_11_37.ucore.bz2",
"href": "/api/support/coredump/coredumps/d583d44e-e9c6-11eb-a270-005056bb47f9/mlogd.979.4136886421.2021-07-22.01_11_37.ucore.bz2"
"num_records": 4,
"href": "/api/support/coredump/coredumps"
2) Retrieving a specific core dump
The following example returns the requested core dump. If there is no core dump with the requested node UUID and name, an error is returned.
# The API:
/api/support/coredump/coredumps/{node.uuid}/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/coredump/coredumps/d583d44e-e9c6-11eb-a270-005056bb47f9/core.4136886421.2021-07-21.17_57_02.nz" -H "accept: application/hal+json"
# The response:
"node": {
"name": "node1",
"type": "kernel",
"panic_time": "2021-07-21T13:57:02-04:00",
"size": 945111148,
"md5_data_chksum": "611a6fa50d230a1af402f3724ab320af",
"is_saved": true,
3) Deleting a core dump
The following example deletes the requested core dump. If there is no core dump with the requested node UUID and name to delete, an error is returned.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/coredump/coredumps/d583d44e-e9c6-11eb-a270-005056bb47f9/mlogd.979.4136886421.2021-07-22.01_11_37.ucore.bz2" -H "accept: application/hal+json"
# The response header:
HTTP/1.1 200 OK
Date: Thu, 22 Jul 2021 01:32:24 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 3
Content-Type: application/hal+json
