Manage Ethernet switches
Access and modify configuration details of ethernet switches within cluster and storage networks using specific API calls. Retrieve comprehensive status and configuration information or adjust switch states as needed.
Overview
This API can be used to get information about the ethernet switches used for cluster and/or storage networks. This API support GET and PATCH calls. The GET operation returns a list of discovered switches with status and configuration information. The PATCH can be used to modify state of the switch.
Retrieving the ethernet switches for a cluster
The following example retrieves the ONTAP switches from the cluster. Note that if the fields=* parameter is not specified, the fields snmp.version, snmp.credential, model, sw-version, reason, version-source, monitoring.enable, monitoring.subsystem.type and monitoring.subsystem.poll_interval are not returned. Filters can be added on the fields to limit the results.
# The API:
GET network/ethernet/switches
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ethernet/switches?return_records=true" -H "accept: application/json" -H "Content-Type: application/hal+json"
# The response:
"records": [
"name": "RTP-CS01-510R11(FOC22092K12)",
"address": "172.26.207.77",
"discovered": true,
"model": "NX3232C",
"monitoring": {
"monitored": true,
"reason": "None"
"network": "cluster",
"serial_number": "Unknown",
"snmp": {
"version": "snmpv2c",
"user": "cshm1!"
"version": "Cisco Nexus Operating System (NX-OS) Software, Version 9.2(3)",
"href": "/api/network/ethernet/switches/RTP-CS01-510R11%28FOC22092K12%29"
"name": "RTP-CS01-510R12(FOC22373C3P)",
"address": "172.26.207.82",
"discovered": true,
"model": "NX3232C",
"monitoring": {
"monitored": true,
"reason": "None"
"serial_number": "FOC22373C3P",
"snmp": {
"user": "cshm1!"
"href": "/api/network/ethernet/switches/RTP-CS01-510R12%28FOC22373C3P%29"
"name": "RTP-SS01-510R10(FOC22170DFR)",
"address": "172.26.207.65",
"discovered": true,
"model": "NX3232C",
"monitoring": {
"monitored": true,
"reason": "None"
"network": "storage",
"serial_number": "FOC22170DFR",
"snmp": {
"user": "cshm1!"
"version": "Cisco Nexus Operating System (NX-OS) Software, Version 9.3(3)",
"href": "/api/network/ethernet/switches/RTP-SS01-510R10%28FOC22170DFR%29"
"name": "RTP-SS02-510R10(FOC22131U6T)",
"address": "172.26.207.66",
"discovered": true,
"model": "NX3232C",
"monitoring": {
"monitored": true,
"reason": "None"
"serial_number": "FOC22131U6T",
"snmp": {
"user": "cshm1!"
"href": "/api/network/ethernet/switches/RTP-SS02-510R10%28FOC22131U6T%29"
"num_records": 4,
"href": "/api/network/ethernet/switches?fields=*&return_records=true"
Retrieving an ethernet switch for a cluster
The following example retrieves a single switch by the switchname using the API.
# The API:
GET /network/ethernet/switches{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ethernet/switches/RTP-SS02-510R10(FOC22131U6T?return_records=true" -H "accept: application/json" -H "Content-Type: application/hal+json"
# The response:
"discovered": true,
"model": "NX3232C",
"monitoring": {
"monitored": true,
"reason": "None"
"snmp": {
"user": "cshm1!"
"href": "/api/network/ethernet/switches/RTP-SS02-510R10(FOC22131U6T)"
Configuring a switch
The following example configures SNMP credential and version on a switch.
# The API:
PATCH /network/ethernet/switches{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/network/ethernet/switches/sconqa-corduroyl-03" -H "accept: application/json" -H "Content-Type: application/hal+json" -d "{ \"snmp\": { \"version\": \"snmpv2c\", \"user\": \"cshm1!\"}}"
# The response:
