REST API reference
Manage S3 service policies
Manage S3 service policies to define permissions for resources such as buckets and objects. Use these endpoints to control access to storage resources within your environment.
Overview
An S3 policy is an object that when associated with a resource, defines their permissions. Buckets and objects are defined as resources. Policies are used to manage access to these resources.
Retrieving all fields for all S3 policies of an SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/policies:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"num_records": 2,
"records": [
    "comment": "S3 policy.",
    "name": "Policy1",
    "statements": [
        "actions": [
        "effect": "allow",
        "index": 0,
        "resources": [
          "bucket1",
          "bucket1/*"
        "sid": "FullAccessToBucket1"
        "actions": [
          "DeleteObject"
        "effect": "deny",
        "index": 1,
        "resources": [
        "sid": "DenyDeleteObjectAccessToAllResources"
    "svm": {
      "name": "svm1",
    "comment": "S3 policy 2.",
    "name": "Policy2",
    "statements": [
        "actions": [
          "GetObject"
        "effect": "allow",
        "index": 3,
        "resources": [
        "sid": "AllowGetObjectAccessToAllResources"
        "actions": [
        "effect": "deny",
        "index": 3,
        "resources": [
        "sid": "DenyAccessToAllResources"
    "svm": {
      "name": "svm1",
Retrieving the specified policy in the SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/policies/{name}:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies/Policy1?fields=*" -H "accept: application/json"
# The response:
"name": "Policy1",
"statements": [
    "actions": [
      "GetObject",
      "PutObject",
      "DeleteObject",
      "ListBucket",
      "ListMyBuckets",
      "ListBucketMultipartUploads",
      "ListMultipartUploadParts",
      "GetObjectTagging",
      "PutObjectTagging",
      "DeleteObjectTagging",
    "effect": "deny",
    "index": 0,
    "resources": [
"svm": {
  "name": "svm1",
Creating an S3 policy for an SVM
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies?return_records=true" -H "accept: application/json" -H "authorization: Basic YWRtaW46bmV0YXBwMSE=" -H "Content-Type: application/json" -d "{ \"comment\": \"S3 policy.\", \"name\": \"Policy1\", \"statements\": [ { \"actions\": [ \"ListBucket\", \"ListMyBuckets\" ], \"effect\": \"allow\", \"resources\": [ \"*\" ], \"sid\": \"AllowListAccessToAllResources\" } ]}"
# The response:
HTTP/1.1 202 Accepted
Date: Mon, 16 Mar 2020 11:32:27 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 289
"num_records": 1,
"records": [
    "name": "Policy1",
    "statements": [
        "actions": [
          "ListBucket",
          "ListMyBuckets"
        "effect": "allow",
        "index": 5,
        "resources": [
        "sid": "AllowListAccessToAllResources"
    "svm": {
      "name": "svm1",
Updating an S3 policy for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies/Policy1" -H "accept: application/json" -H "authorization: Basic YWRtaW46bmV0YXBwMSE=" -H "Content-Type: application/json" -d "{ \"comment\": \"S3 policy.\", \"statements\": [ { \"actions\": [ \"GetObject\", \"PutObject\", \"DeleteObject\", \"ListBucket\", \"ListMyBuckets\"], \"effect\": \"allow\", \"resources\": [ \"bucket1\", \"bucket1/*\" ], \"sid\": \"FullAccessToAllResources\" } ]}"
# The response:
Content-Length: 189
Deleting an S3 policy for a specified SVM
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies/Policy1" -H "accept: application/json"
# The response:
Content-Length: 189
