REST API reference
Manage SVM peer relationships
SVM peer endpoints enable you to establish and manage peering relationships between storage virtual machines. Use these APIs to create, view, update, and delete SVM peers, facilitating shared resources and collaboration across your storage environment.
Managing SVM peers
The SVM peer commands allow you to create and manage SVM peering relationships.
SVM peer APIs
The following APIs are used to manage SVM peers:
  • GET /api/svm/peers
  • POST /api/svm/peers
  • GET /api/svm/peers/{uuid}
  • PATCH /api/svm/peers/{uuid}
  • DELETE /api/svm/peers/{uuid}
