REST API reference
Manage UNIX group configurations
Use the UNIX group configuration endpoints to display and manage local UNIX group information within your ONTAP environment. These endpoints help control configurations related to data SVMs, facilitating streamlined management of UNIX groups.
Overview
You can use this API to display local UNIX group information and to control UNIX group configurations.
Retrieving UNIX group information
The UNIX group GET endpoint retrieves all of the local UNIX groups configurations for data SVMs.
Retrieving all of the fields for all of the UNIX group configurations
# The API:
/api/name-services/unix-groups
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/unix-groups?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "b009a9e7-4081-b576-7575-ada21efcaf16",
      "name": "vs1",
          "href": "/api/svm/svms/b009a9e7-4081-b576-7575-ada21efcaf16"
    "name": "group1",
    "id": 11,
    "users": [
        "name": "user1"
        "name": "user2"
        "name": "user3"
        "href": "/api/name-services/unix-groups/b009a9e7-4081-b576-7575-ada21efcaf16/group1"
    "svm": {
      "name": "vs1",
    "name": "group2",
    "id": 12,
    "users": [
        "name": "user1"
        "name": "user2"
        "href": "/api/name-services/unix-groups/b009a9e7-4081-b576-7575-ada21efcaf16/group2"
    "svm": {
      "uuid": "b009a9e7-4081-b576-7575-ada21efcad17",
      "name": "vs2",
          "href": "/api/svm/svms/b009a9e7-4081-b576-7575-ada21efcad17"
    "name": "group1",
    "id": 11,
    "users": [
        "name": "user2"
        "name": "user3"
        "href": "/api/name-services/unix-groups/b009a9e7-4081-b576-7575-ada21efcad17/group1"
"num_records": 3,
    "href": "/api/name-services/unix-groups?fields=*"
Retrieving all of the UNIX group configurations whose group name is 'group1'.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/unix-groups?name=group1" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "name": "vs1",
    "name": "group1",
    "id": 11,
"num_records": 1,
    "href": "/api/name-services/unix-groups?name=group1"
Creating a UNIX group configuration
The UNIX group POST endpoint creates a UNIX group configuration for the specified SVM.
Example
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/unix-groups" -H "accept: application/hal+json" -H "Content-Type: application/json" -d '{ "svm": {"uuid": "179d3c85-7053-11e8-b9b8-005056b41bd1"}, "name": "group1", "id": 111}'
Updating a UNIX group configuration
The UNIX group PATCH endpoint updates the UNIX group ID of the specified UNIX group and the specified SVM.
Example
Modify the group ID of group1 to 112
# The API:
/api/name-services/unix-groups/{svm.uuid}/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/unix-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/group1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d '{ "id": 112}'
Deleting a UNIX group configuration
The UNIX group DELETE endpoint deletes the specified UNIX group of the specified SVM.
Example
Delete the group 'group1'
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/name-services/unix-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/group1" -H "accept: application/hal+json"
