REST API reference
Update a specific FPolicy engine configuration for an SVM
Updates the configuration of an FPolicy engine for a Storage Virtual Machine (SVM), tailoring it to the specific needs of your environment.
HTTP method and endpoint
PATCH /protocols/fpolicy/{svm.uuid}/engines/{name}
Introduced in
ONTAP 9.6
Usage notes
Updates a specific FPolicy engine configuration of an SVM. Modification of an FPolicy engine that is attached to one or more enabled FPolicy policies is not allowed.
  • fpolicy policy external-engine modify
name
string
path
True
svm.uuid
string
path
True
Request Body
Name Type Description
port
integer
Port number of the FPolicy server application.
primary_servers
array[string]
secondary_servers
array[string]
svm
svm
type
string
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
  • synchronous - After sending a notification, wait for a response from the FPolicy server.
  • asynchronous - After sending a notification, file request processing continues.
    • Default value: 1
    • enum: ["synchronous", "asynchronous"]
    • Introduced in: 9.6
Example request
  "port": 9876,
  "primary_servers": [
    "10.132.145.20",
    "10.140.101.109"
  "secondary_servers": [
    "10.132.145.20",
    "10.132.145.21"
  "svm": {
    "uuid": "string"
  "type": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
9764922
The primary and secondary server has a redundant IP address
9764942
At least one FPolicy policy is using the FPolicy engine
9764886
FPolicy engine is a cluster-level FPolicy engine
svm
uuid
string
SVM UUID
fpolicy_engine
The engine defines how ONTAP makes and manages connections to external FPolicy servers.
port
integer
primary_servers
array[string]
secondary_servers
array[string]
svm
svm
type
string
    • Default value: 1
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
