REST API reference
Create an initiator group
Creates an initiator group to manage access to LUNs for a specific set of initiators. This is essential when you need to define and control which hosts can access storage resources in your ONTAP environment.
HTTP method and endpoint
POST /protocols/san/igroups
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the initiator group.
  • name - Name of the initiator group.
  • os_type - Operating system of the initiator group's initiators.
  • initiators.name - Name(s) of initiator group's initiators. This property can be used to create the initiator group and populate it with initiators in a single request.
Default property values
If not specified in POST, the following default property values are assigned.
  • protocol - mixed - Data protocol of the initiator group's initiators.
  • lun igroup create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
delete_on_unmap
boolean
An option that causes the initiator group to be deleted when the last LUN map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the initiator group is created.
igroups
array[igroup_child]
The initiator groups that are members of the group. Optional in POST.
This property is mutually exclusive with the initiators property during POST.
This array contains only the direct children of the initiator group. If the member initiator groups have further nested initiator groups, those are reported in the igroups property of the child initiator group.
Zero or more nested initiator groups can be supplied when the initiator group is created. The initiator group will act as if it contains the aggregatation of all initiators in any nested initiator groups.
After creation, nested initiator groups can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/igroups endpoint. See POST /protocols/san/igroups/{igroup.uuid}/igroups and DELETE /protocols/san/igroups/{igroup.uuid}/igroups/{uuid} for more details.
initiators
array[initiators]
The initiators that are members of the group or any group nested below this group. Optional in POST.
This property is mutually exclusive with the igroups property during POST.
During GET, this array contains initiators that are members of this group or any nested initiator groups below this group. When initiators of nested groups are returned, they include links to the initiator group that directly contains the initiator.
Zero or more initiators can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. See POST /protocols/san/igroups/{igroup.uuid}/initiators and DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name} for more details.
lun_maps
array[lun_maps]
All LUN maps with which the initiator is associated.
If the requested igroup is part of a remote, non-local, MetroCluster SVM, the LUN maps are not retrieved.
There is an added cost to retrieving property values for lun_maps. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
parent_igroups
array[]
The initiator groups that contain this initiator group as as member.
portset
portset
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset.
Optional in POST and PATCH. PATCH portset.name to an empty string ("") to unbind a portset from the initiator group.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed.
The protocol of an initiator group cannot be changed after creation of the group.
supports_igroups
boolean
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. This property is true when initiator groups can be added to this initiator group. The initiators.name property cannot be used to determine this via a query because it reports initiators inherited from nested igroups.
svm
svm
uuid
string
The unique identifier of the initiator group.
Example request
  "comment": "string",
  "igroups": [
      "name": "igroup1",
  "initiators": [
      "igroup": {
        "name": "igroup1",
      "name": "iqn.1998-01.com.corp.iscsi:name1"
  "lun_maps": [
      "logical_unit_number": 0,
      "lun": {
        "name": "lun1",
        "node": {
          "name": "node1",
  "name": "igroup1",
  "os_type": "string",
  "portset": {
    "name": "portset1",
  "protocol": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records.
records
array[igroup]
  "records": [
      "igroups": [
          "name": "igroup1",
      "initiators": [
          "igroup": {
            "name": "igroup1",
      "lun_maps": [
          "lun": {
            "name": "lun1",
            "node": {
              "name": "node1",
      "name": "igroup1",
      "portset": {
        "name": "portset1",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The supplied SVM does not exist.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5373958
An invalid initiator group name was supplied.
5373966
An initiator group cannot be created in an SVM that is configured for NVMe.
5373969
A supplied initiator name looks like an iSCSI IQN initiator, but the portions after the prefix are missing.
5373971
A supplied initiator name looks like an iSCSI IQN initiator, but the date portion is invalid.
5373972
A supplied initiator name looks like an iSCSI IQN initiator, but the naming authority portion is invalid.
5373977
A supplied initiator name looks like an iSCSI EUI initiator, but the length is invalid.
5373978
A supplied initiator name looks like an iSCSI EUI initiator, but the format is invalid.
5373992
A supplied initiator name was too long to be valid.
5373993
A supplied initiator name did not match any valid format.
5374023
An initiator group with the same name already exists.
5374027
An attempt was made to bind a portset with no member network interfaces to the initiator group.
5374028
An attempt was made to bind a portset with an incompatible protocol to the initiator group.
5374038
An invalid Fibre Channel WWPN was supplied.
5374039
An invalid iSCSI initiator name was supplied.
5374040
Initiators and child initiator groups were both supplied, but only one option is allowed.
5374732
An initiator is already in another initiator group with a conflicting operating system type.
5374735
An attempt was made to add a child igroup that would exceed the maximum allowable depth.
5374737
A supplied child initiator group already exists in another initiator group's hierarchy.
5374739
A supplied child initiator group has an operating system type that differs from the parent initiator group.
5374740
A supplied child initiator group has an protocol that differs from the parent initiator group.
5374741
A supplied child initiator group is already owned by a different child in the initiator group's hierarchy.
5374742
A supplied child initiator group contains an initiator that is already owned by another initiator group in the hierarchy.
5374746
The cluster is currently running in a mixed version and nested initiator groups cannot be created until the effective cluster version reaches 9.9.1.
5374747
The cluster is currently running in a mixed version and initiator group comments cannot be created until the effective cluster version reaches 9.9.1.
5374917
Multiple matching initiators have been supplied with conflicting comments.
string
igroup_child
comment
string
igroups
array[]
Further nested initiator groups.
name
string
uuid
string
self
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group.
string
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
name
string
uuid
string
initiators
comment
string
igroup
igroup
name
string
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the records property is used.
An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
node
name
string
uuid
string
lun
The LUN to which the initiator group is mapped.
name
string
The name of the LUN.
node
node
uuid
string
The unique identifier of the LUN.
lun_maps
A LUN map with which the initiator group is associated.
logical_unit_number
integer
The logical unit number assigned to the LUN for initiators in the initiator group.
lun
lun
portset
name
string
The name of the portset.
uuid
string
The unique identifier of the portset.
svm
name
string
The name of the SVM.
uuid
string
igroup
An initiator group (igroup) is a collection of Fibre Channel (FC) world wide port names (WWPNs), and/or iSCSI Qualified Names (IQNs), and/or iSCSI EUIs (Extended Unique Identifiers) that identify host initiators.
Initiator groups are used to control which hosts can access specific LUNs. To grant access to a LUN from one or more hosts, create an initiator group containing the host initiator names, then create a LUN map that associates the initiator group with the LUN.
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. When a parent initiator group is mapped, it inherits all of the initiators of any initiator groups nested below it. If any nested initiator group is modified to contain different initiators, the parent initiator groups inherit the change. A parent can have many nested initiator groups and an initiator group can be nested under multiple parents. Initiators can only be added or removed from the initiator group that directly contains them. The maximum supported depth of nesting is three layers.
Best practice when using nested initiator groups is to match host hierarchies. A single initiator group should correspond to a single host. If a LUN needs to be mapped to multiple hosts, the initiator groups representing those hosts should be aggregated into a parent initiator group and the LUN should be mapped to that initiator group. For multi-ported hosts, initiators have a comment property where the port corresponding to the initiator can be documented.
An initiator can appear in multiple initiator groups. An initiator group can be mapped to multiple LUNs. A specific initiator can be mapped to a specific LUN only once. With the introduction of nestable initiator groups, best practice is to use the hierarchy such that an initiator is only a direct member of a single initiator group, and that initiator group can then be referenced by other initiator groups.
All initiators or nested initiator groups in an initiator group must be from the same operating system. The initiator group's operating system is specified when the initiator group is created.
When an initiator group is created, the protocol property is used to restrict member initiators to Fibre Channel (fcp), iSCSI (iscsi), or both (mixed). Initiator groups within a nested hierarchy may not have conflicting protocols.
Zero or more initiators or nested initiator groups can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. Initiator groups containing other initiator groups report the aggregated list of initiators from all nested initiator groups, but modifications of the initiator list must be performed on the initiator group that directly contains the initiators. See POST /protocols/san/igroups/{igroup.uuid}/initiators and DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name} for more details.
comment
string
delete_on_unmap
boolean
igroups
array[igroup_child]
initiators
array[initiators]
lun_maps
array[lun_maps]
name
string
os_type
string
parent_igroups
array[]
portset
portset
protocol
string
supports_igroups
boolean
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
