Protocols cifs local-groups endpoint overview
Overview
The CIFS server can use local groups for authorization when determining share, file and directory access rights. You can use this API to display local group information and to control local group configurations.
Retrieving local group information
The local group GET endpoint retrieves all of the local groups configurations for data SVMs.
Retrieving all of the fields for all of the local group configurations
# The API:
/api/protocols/cifs/local-groups
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/local-groups?fields=**" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "b009a9e7-4081-b576-7575-ada21efcaf16",
"name": "vs1"
"sid": "S-1-5-32-544",
"name": "BUILTIN\\Administrators",
"description": "Built-in Administrators group",
"members": [
"name": "CIFS_SERVER\\Administrator"
"name": "AD_DOMAIN\\Domain Admins"
"svm": {
"name": "vs1"
"sid": "S-1-5-32-545",
"name": "BUILTIN\\Users",
"description": "All users",
"members": [
"name": "AD_DOMAIN\\Domain Users"
"svm": {
"name": "vs1"
"sid": "S-1-5-32-546",
"name": "BUILTIN\\Guests",
"description": "Built-in Guests Group",
"members": [
"name": "SACHILDAP02\\Domain Guests"
"svm": {
"name": "vs1"
"sid": "S-1-5-32-547",
"name": "BUILTIN\\Power Users",
"description": "Restricted administrative privileges"
"svm": {
"name": "vs1"
"sid": "S-1-5-32-551",
"name": "BUILTIN\\Backup Operators",
"description": "Backup Operators group"
"svm": {
"name": "vs1"
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"name": "CIFS_SERVER\\group2",
"description": "local group2"
"svm": {
"uuid": "5060077c-5be6-11eb-90b7-0050568e5169",
"name": "vs2"
"members": [
"name": "VS2.CIFS\\Administrator"
"name": "VS2.CIFS\\user3"
"name": "SACHILDAP02\\Domain Admins"
"svm": {
"name": "vs2"
"members": [
"name": "SACHILDAP02\\Domain Users"
"svm": {
"name": "vs2"
"members": [
"svm": {
"name": "vs2"
"svm": {
"name": "vs2"
"svm": {
"name": "vs2"
"sid": "S-1-5-21-1625922807-3304708894-3529444428-1001",
"name": "CIFS_SERVER\\group1",
"description": "local group1"
"num_records": 12
Retrieving a local group configuration of a specific SVM and group
# The API:
/api/protocols/cifs/local-groups/{svm.uuid}/{sid}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/local-groups/25b363a6-2971-11eb-88e1-0050568eefd4/S-1-5-21-256008430-3394229847-3930036330-1001" -H "accept: application/json"
# The response:
"svm": {
"uuid": "25b363a6-2971-11eb-88e1-0050568eefd4",
"name": "vs1"
"description": "local group"
Creating a local group configuration
The local group POST endpoint creates a local group configuration for the specified SVM.
Example
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/cifs/local-groups" -H "accept: application/json" -H "Content-Type: application/json" -d '{ "svm": {"uuid": "179d3c85-7053-11e8-b9b8-005056b41bd1"}, "name": "group1"}'
Updating a local group configuration
The local group PATCH endpoint updates the name and description of the specified local group and the specified SVM.
Example
Update the local group name from 'group1' to 'group2'
# The API:
/api/protocols/local-groups/{svm.uuid}/{sid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/cifs/local-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/S-1-5-21-256008430-3394229847-3930036330-1257" -H "accept: application/json" -H "Content-Type: application/json" -d '{ "name": "group2", "description": "local group"}'
Deleting a local group configuration
The local group DELETE endpoint deletes the specified local group of the specified SVM.
Example
Delete the local group 'group1'
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/local-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/S-1-5-21-256008430-3394229847-3930036330-1001" -H "accept: application/json"
