ONTAP REST API Protocols cifs local-users endpoints
Overview
The CIFS server can use local users for CIFS authentication. The local users can also be used for authorization when determining both share and file/directory access rights to data residing on the storage virtual machine (SVM). You can use this API to display local user information and to control local user configurations.
Retrieving local user information
You can use the local user GET endpoint to retrieve all of the local user configurations for data SVMs.
Retrieving all of the fields for local user configurations for all SVMs
# The API:
/api/protocols/cifs/local-users
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/local-users?fields=**" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "25b363a6-2971-11eb-88e1-0050568eefd4",
"name": "vs1"
"sid": "S-1-5-21-256008430-3394229847-3930036330-500",
"name": "CIFS_SERVER1\\Administrator",
"full_name": "",
"description": "Built-in administrator account",
"account_disabled": false,
"membership": [
"name": "BUILTIN\\Administrators",
"sid": "S-1-5-32-544"
"svm": {
"name": "vs1"
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"name": "CIFS_SERVER1\\user1",
"full_name": "local user1",
"description": "This is CIFS local user",
"svm": {
"name": "vs1"
"sid": "S-1-5-21-256008430-3394229847-3930036330-1002",
"name": "CIFS_SERVER1\\user2",
"full_name": "local user2",
"membership": [
"name": "CIFS_SERVER1\\grp1",
"name": "CIFS_SERVER1\\grp2",
"svm": {
"uuid": "3f479a01-2971-11eb-88e1-0050568eefd4",
"name": "vs2"
"sid": "S-1-5-21-1625922807-3304708894-3529444428-500",
"name": "CIFS_SERVER2\\Administrator",
"full_name": "",
"membership": [
"svm": {
"name": "vs2"
"sid": "S-1-5-21-1625922807-3304708894-3529444428-1001",
"name": "CIFS_SERVER2\\user1",
"num_records": 5
Retrieving the local user configuration of a specific SVM
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/local-users?svm.uuid=25b363a6-2971-11eb-88e1-0050568eefd4&fields=**" -H "accept: application/json"
# The response:
"records": [
"svm": {
"name": "vs1"
"full_name": "",
"membership": [
"svm": {
"name": "vs1"
"svm": {
"name": "vs1"
"membership": [
"num_records": 3
Retrieving a local user configuration of a specific SVM and user
# The API:
/api/protocols/cifs/local-users/{svm.uuid}/{sid}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/local-users/25b363a6-2971-11eb-88e1-0050568eefd4/S-1-5-21-1625922807-3304708894-3529444428-1001" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1"
Creating a local user configuration
The local user POST endpoint creates a local user configuration for the specified SVM.
Creating a local user configuration with all fields specified
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/cifs/local-users" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"account_disabled\": false, \"description\": \"This is local user.\", \"full_name\": \"user name\", \"name\": \"SMB_SERVER01\\\\user\", \"password\": \"netapp1N\", \"svm\": { \"name\": \"vs1\", \"uuid\": \"25b363a6-2971-11eb-88e1-0050568eefd4\" }}"
Creating a local user configuration with only mandatory fields specified
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/cifs/local-users" -H "accept: application/json" -d "{ \"name\": \"user1\", \"password\": \"netapp1N\", \"svm\": { \"uuid\": \"25b363a6-2971-11eb-88e1-0050568eefd4\" }}"
Updating a local user configuration
The local user PATCH endpoint updates the local user configuration for the specified user and SVM.
Updating a local user name and password
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/cifs/local-users/25b363a6-2971-11eb-88e1-0050568eefd4/S-1-5-21-1625922807-3304708894-3529444428-1001" -H "accept: application/json" -d "{ \"name\": \"new_user1\", \"password\": \"netapp1Net\" }"
Deleting a local user configuration
The local user DELETE endpoint deletes the specified local user for the specified SVM. The following example shows a DELETE operation:
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/local-users/25b363a6-2971-11eb-88e1-0050568eefd4/S-1-5-21-1625922807-3304708894-3529444428-1001" -H "accept: application/json"
