REST API reference
Retrieve clients
Overview
You can use this API to retrieve a list of clients with the most IO activity for a specified volume. Use the top_metric parameter to specify which type of IO activity to filter for. This API is used to provide insight into IO activity and supports ordering by IO activity types, namely iops and throughput metrics. This API supports only returning one IO activity type per request.
Failure to return list of clients with most IO activity
The API can sometimes fail to return the list of clients with the most IO activity, due to the following reasons:
– The volume does not have the activity tracking feature enabled.
– The volume does not have read/write traffic.
– The read traffic is served by the NFS/CIFS client filesystem cache.
– On rare occasions, the incoming traffic pattern is not suitable to obtain the list of clients with the most IO activity.
Retrieve a list of the clients with the most IO activity
For a report on the clients with the most IO activity returned in descending order, specify the IO activity type you want to filter for by passing the iops or throughput IO activity type into the top_metric parameter. If the IO activity type is not specified, by default the API returns a list of clients with the greatest number of average read operations per second. The maximum number of clients returned by the API for an IO activity type is 25.
– GET /api/storage/volumes/{volume.uuid}/top-metrics/clients
Retrieving a list of the clients with the greatest average number of write operations per second:
# The API:
# The Call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/top-metrics/clients?top_metric=iops.write"
# The Response:
"records": [
    "volume": {
      "name": "vol1"
    "iops": {
      "write": 1495,
      "error": {
        "lower_bound": 1495,
        "upper_bound": 1505
    "client_ip": "172.28.71.128",
    "svm": {
      "uuid": "572361f3-e769-439d-9c04-2ba48a08ff43",
      "name": "vs1",
          "href": "/api/svm/svms/572361f3-e769-439d-9c04-2ba48a08ff43"
    "volume": {
      "name": "vol1"
    "iops": {
      "write": 1022,
      "error": {
        "lower_bound": 1022,
        "upper_bound": 1032
    "client_ip": "172.28.71.179",
    "svm": {
      "name": "vs1",
    "volume": {
      "name": "vol1"
    "iops": {
      "write": 345,
      "error": {
        "lower_bound": 345,
        "upper_bound": 355
    "client_ip": "172.28.51.62",
    "svm": {
      "name": "vs1",
"num_records": 3,
    "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/top-metrics/clients?top_metric=iops.write"
Example showing the behavior of the API when there is no read/write traffic:
# The Call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/top-metrics/clients?top_metric=throughput.write"
# The Response:
"records": [
"num_records": 0,
"notice": {
  "message": "The activity tracking report for volume \"FV\" in SVM \"vs0\" returned zero records. Check whether the volume have read/write traffic. Refer to the REST API documentation for more information on why there might be no records.",
  "code": "124518418"
    "href": "/api/storage/volumes/9af63729-8ac8-11ec-b1bc-005056a79da4/top-metrics/clients?top_metric=throughput.write"
