ONTAP REST API Security endpoints
Overview
You can use this API for various cluster-wide security-related operations.
"onboard_key_manager_configurable_status" object
Use this API to retrieve details of whether or not the Onboard Key Manager can be configured on the cluster.
– GET /api/security
– GET /api/security?fields=onboard_key_manager_configurable_status
"software_data_encryption" object
Contains software data encryption related information.
The following APIs can be used to enable or disable and obtain default software data at rest encryption values:
– PATCH /api/security -d '{ "software_data_encryption.disabled_by_default" : true }'
– PATCH /api/security -d '{ "software_data_encryption.disabled_by_default" : false }'
– GET /api/security
– GET /api/security?fields=software_data_encryption
A PATCH request on this API using the parameter "software_data_encryption.conversion_enabled" triggers the conversion of all non-encrypted metadata volumes to encrypted metadata volumes and all non-NAE aggregates to NAE aggregates. For the conversion to start, the cluster must have either an Onboard or an external key manager set up and the aggregates should either be empty or have only metadata volumes. No data volumes should be present in any of the aggregates. For MetroCluster configurations, the PATCH request will fail if the cluster is in the switchover state.
The following API can be used to initiate software data encryption conversion.
– PATCH /api/security -d '{ "software_data_encryption.conversion_enabled" : true }'
"fips" object
Contains FIPS mode information.
A PATCH request on this API using the parameter "fips.enabled" switches the system from using the default cryptographic module software implementations to validated ones or vice versa, where applicable. If the value of the parameter is "true" and unapproved algorithms are configured as permitted in relevant subsystems, those algorithms will be disabled in the relevant subsystem configurations. If "false", there will be no implied change to the relevant subsystem configurations.
– GET /api/security
– GET /api/security?fields=fips
– PATCH /api/security -d '{ "fips.enabled" : true }'
– PATCH /api/security -d '{ "fips.enabled" : false }'
"tls" object
Contains TLS configration information.
A PATCH request on this API using the parameter "tls.cipher_suites" and/or "tls.protocol_versions" configures the permissible cipher suites and/or protocol versions for all TLS-enabled applications in the system.
– GET /api/security
– GET /api/security?fields=tls
– PATCH /api/security -d '{ "tls" : { "protocol_versions" : ["TLSv1.2", "TLSv1.1"], "cipher_suites" : ["TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384", "TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256"] } }'
"management_protocols" object
Contains Security Protocols information.
This security protocols endpoint is used to retrieve and configure security protocols.
– GET /api/security
– GET /api/security?fields=management_protocols
– PATCH /api/security -d '{ "management_protocols" : { "rsh_enabled" : true } }'
– PATCH /api/security -d '{ "management_protocols" : { "rsh_enabled" : false } }'
– PATCH /api/security -d '{ "management_protocols" : { "telnet_enabled" : true } }'
– PATCH /api/security -d '{ "management_protocols" : { "telnet_enabled" : false } }'
– PATCH /api/security -d '{ "management_protocols" : { "rsh_enabled" : true, "telnet_enabled" : true } }'
GET Examples
Retrieving information about the security configured on the cluster
The following example shows how to retrieve the configuration of the cluster.
# The API:
GET /api/security:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security?fields=*' -H 'accept: application/hal+json'
# The response:
"onboard_key_manager_configurable_status": {
"supported": false,
"message": "Onboard Key Manager cannot be configured on the cluster. There are no self-encrypting disks in the cluster, and the following nodes do not support volume granular encryption: ntap-vsim2.",
"code": 65537300
"fips": {
"enabled": false
"tls": {
"cipher_suites": [
"TLS_RSA_WITH_AES_128_GCM_SHA256",
"TLS_RSA_WITH_AES_128_CBC_SHA",
"TLS_RSA_WITH_AES_128_CBC_SHA256",
"TLS_RSA_WITH_AES_256_GCM_SHA384",
"TLS_RSA_WITH_AES_256_CBC_SHA",
"TLS_RSA_WITH_AES_256_CBC_SHA256",
"TLS_RSA_WITH_CAMELLIA_128_CBC_SHA",
"TLS_RSA_WITH_CAMELLIA_256_CBC_SHA",
"TLS_DHE_DSS_WITH_AES_128_GCM_SHA256",
"TLS_DHE_DSS_WITH_AES_128_CBC_SHA",
"TLS_DHE_DSS_WITH_AES_128_CBC_SHA256",
"TLS_DHE_DSS_WITH_AES_256_GCM_SHA384",
"TLS_DHE_DSS_WITH_AES_256_CBC_SHA",
"TLS_DHE_DSS_WITH_AES_256_CBC_SHA256",
"TLS_DHE_DSS_WITH_CAMELLIA_128_CBC_SHA",
"TLS_DHE_DSS_WITH_CAMELLIA_256_CBC_SHA",
"TLS_DHE_DSS_WITH_SEED_CBC_SHA",
"TLS_DHE_RSA_WITH_AES_128_GCM_SHA256",
"TLS_DHE_RSA_WITH_AES_128_CBC_SHA",
"TLS_DHE_RSA_WITH_AES_128_CBC_SHA256",
"TLS_DHE_RSA_WITH_AES_256_GCM_SHA384",
"TLS_DHE_RSA_WITH_AES_256_CBC_SHA",
"TLS_DHE_RSA_WITH_AES_256_CBC_SHA256",
"TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA",
"TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA",
"TLS_DHE_RSA_WITH_SEED_CBC_SHA",
"TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256",
"TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA",
"TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256",
"TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384",
"TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA",
"TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384",
"TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256",
"TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA",
"TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256",
"TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA",
"TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384",
"TLS_PSK_WITH_AES_128_CBC_SHA",
"TLS_PSK_WITH_AES_128_GCM_SHA256",
"TLS_PSK_WITH_AES_256_CBC_SHA",
"TLS_PSK_WITH_AES_256_GCM_SHA384",
"TLS_RSA_WITH_SEED_CBC_SHA",
"TLS_SRP_SHA_WITH_AES_128_CBC_SHA",
"TLS_SRP_SHA_WITH_AES_256_CBC_SHA",
"TLS_SRP_SHA_DSS_WITH_AES_128_CBC_SHA",
"TLS_SRP_SHA_DSS_WITH_AES_256_CBC_SHA",
"TLS_SRP_SHA_RSA_WITH_AES_128_CBC_SHA",
"TLS_SRP_SHA_RSA_WITH_AES_256_CBC_SHA"
"protocol_versions": [
"TLSv1.2",
"TLSv1.1"
"management_protocols": {
"rsh_enabled": false,
"telnet_enabled": false
== PATCH Examples
=== Enabling software encryption conversion in the cluster
The following example shows how to convert all the aggregates and metadata volumes in the cluster from non-encrypted to encrypted.
= The API:
PATCH /api/security
= The call
curl -X PATCH "https://+++<mgmt_ip>+++/api/security" -d '{ "software_data_encryption.conversion_enabled" : true }'+++</mgmt_ip>+++
= The response:
"job": {
"uuid": "ebcbd82d-1cd4-11ea-8f75-005056ac4adc",
"href": "/api/cluster/jobs/ebcbd82d-1cd4-11ea-8f75-005056ac4adc"
This returns a job UUID. A subsequent GET for this job UUID returns details of the job.
= The call
curl -X GET "https://+++<mgmt_ip>+++/api/cluster/jobs/ebcbd82d-1cd4-11ea-8f75-005056ac4adc"+++</mgmt_ip>+++
= The response:
"description": "PATCH /api/security",
"state": "success",
"message": "success",
"code": 0,
"start_time": "2019-12-12T06:45:40-05:00",
"end_time": "2019-12-12T06:45:40-05:00",
[discrete]
=== Enabling FIPS mode in the cluster
The following example shows how to enable FIPS mode in the cluster.
= The API:
PATCH /api/security
= The call
curl -X PATCH "https://+++<mgmt_ip>+++/api/security" -d '{ "fips.enabled" : true }'+++</mgmt_ip>+++
= The response:
"job": {
"uuid": "8e7f59ee-a9c4-4faa-9513-bef689bbf2c2",
"href": "/api/cluster/jobs/8e7f59ee-a9c4-4faa-9513-bef689bbf2c2"
= The call
curl -X GET "https://+++<mgmt_ip>+++/api/cluster/jobs/8e7f59ee-a9c4-4faa-9513-bef689bbf2c2"+++</mgmt_ip>+++
= The response:
"state": "success",
"code": 0,
"start_time": "2020-04-28T06:55:40-05:00",
"end_time": "2020-04-28T06:55:41-05:00",
[discrete]
=== Configuring permissible TLS protocols and cipher suites in the cluster
The following example shows how to configure the cluster to only allow TLSv1.2 with selected cipher suites.
= The API:
PATCH /api/security
= The call
curl -X PATCH "https://+++<mgmt_ip>+++/api/security" -d '{ "tls" : { "protocol_versions" : ["TLSv1.2"], "cipher_suites" : ["TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384", "TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256"] } }'+++</mgmt_ip>+++
= The response:
"job": {
"uuid": "b45b6290-f4f2-442a-aa0e-4d3ffefe5e0d",
"href": "/api/cluster/jobs/b45b6290-f4f2-442a-aa0e-4d3ffefe5e0d"
= The call
curl -X GET "https://+++<mgmt_ip>+++/api/cluster/jobs/b45b6290-f4f2-442a-aa0e-4d3ffefe5e0d"+++</mgmt_ip>+++
= The response:
"state": "success",
"code": 0,
"start_time": "2021-03-22T08:52:50-05:00",
"end_time": "2021-03-22T08:52:51-05:00",
[discrete]
=== Enabling security protocols in the cluster
The following example shows how to enable the security protocol rsh in the cluster.
= The API:
PATCH /api/security
= The call
curl -X PATCH "https://+++<mgmt_ip>+++/api/security" -d '{ "management_protocols" : { "rsh_enabled" : true } }'+++</mgmt_ip>+++
= The response
"job": {
"uuid": "2980ba28-adab-11eb-8fa3-005056bbfa84",
"href": "/api/cluster/jobs/2980ba28-adab-11eb-8fa3-005056bbfa84"
= The call:
curl -H "accept: application/hal+json" -X GET "https://+++<mgmt-ip>+++/api/security/?fields=management_protocols"+++</mgmt-ip>+++
= The response:
"href": "/api/security"
