REST API reference
storage aggregates uuid endpoints
The ONTAP REST API offers a comprehensive set of endpoints designed to help you manage and automate your storage systems efficiently. This documentation provides detailed information on how to use these API calls, including examples and descriptions of required properties, enabling seamless integration and control over your storage infrastructure.
Updating storage aggregates
The PATCH operation is used to modify properties of the aggregate. There are several properties that can be modified on an aggregate. Only one property can be modified for each PATCH request. PATCH operations on the aggregate's disk count will be blocked while one or more nodes in the cluster are simulating or implementing automatic aggregate creation.
The following is a list of properties that can be modified using the PATCH operation including a brief description for each:
  • name - This property can be changed to rename the aggregate.
  • node.name and node.uuid - Either property can be updated in order to relocate the aggregate to a different node in the cluster.
  • block_storage.mirror.enabled - This property can be changed from 'false' to 'true' in order to mirror the aggregate, if the system is capable of doing so.
  • block_storage.primary.disk_count - This property can be updated to increase the number of disks in an aggregate.
  • block_storage.primary.raid_size - This property can be updated to set the desired RAID size.
  • block_storage.primary.raid_type - This property can be updated to set the desired RAID type.
  • cloud_storage.tiering_fullness_threshold - This property can be updated to set the desired tiering fullness threshold if using FabricPool.
  • data_encryption.software_encryption_enabled - This property enables or disables NAE on the aggregate.
Aggregate expansion
The PATCH operation also supports automatically expanding an aggregate based on the spare disks which are present within the system. Running PATCH with the query "auto_provision_policy" set to "expand" starts the recommended expansion job. In order to see the expected change in capacity before starting the job, call GET on an aggregate instance with the query "auto_provision_policy" set to "expand".
Manual simulated aggregate expansion
The PATCH operation also supports simulated manual expansion of an aggregate. Running PATCH with the query "simulate" set to "true" and "block_storage.primary.disk_count" set to the final disk count will start running the prechecks associated with expanding the aggregate to the proposed size. The response body will include information on how many disks the aggregate can be expanded to, any associated warnings, along with the proposed final size of the aggregate.
Deleting storage aggregates
If volumes exist on an aggregate, they must be deleted or moved before the aggregate can be deleted. See the /storage/volumes API for details on moving or deleting volumes.
Retrieving a specific aggregate from the cluster
The following example shows the response of the requested aggregate. If there is no aggregate with the requested UUID, an error is returned.
# The API:
/api/storage/aggregates/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/870dd9f2-bdfa-4167-b692-57d1cec874d4" -H "accept: application/json"
# The response:
"uuid": "19425837-f2fa-4a9f-8f01-712f626c983c",
"name": "test1",
"node": {
  "uuid": "caf95bec-f801-11e8-8af9-005056bbe5c1",
  "name": "node-1",
"home_node": {
  "name": "node-1",
"space": {
  "block_storage": {
    "size": 235003904,
    "available": 191942656,
    "used": 43061248,
    "full_threshold_percent": 98,
    "physical_used": 5271552,
    "physical_used_percent": 1,
    "volume_footprints_percent": 14,
    "aggregate_metadata": 2655,
    "aggregate_metadata_percent": 8,
    "used_including_snapshot_reserve": 674685,
    "used_including_snapshot_reserve_percent": 35,
    "data_compacted_count": 666666,
    "data_compaction_space_saved": 654566,
    "data_compaction_space_saved_percent": 47,
    "volume_deduplication_shared_count": 567543,
    "volume_deduplication_space_saved": 23765,
    "volume_deduplication_space_saved_percent": 32
  "snapshot": {
    "used_percent": 45,
    "available": 2000,
    "total": 5000,
    "used": 3000,
    "reserve_percent": 20
  "cloud_storage": {
    "used": 0
  "efficiency": {
    "savings": 1408029,
    "ratio": 6.908119720880661,
    "logical_used": 1646350
  "efficiency_without_snapshots": {
    "savings": 0,
    "ratio": 1,
    "logical_used": 737280
  "efficiency_without_snapshots_flexclones": {
    "savings": 5000,
    "ratio": 2,
    "logical_used": 10000
"snapshot": {
  "files_total": 10,
  "files_used": 3,
  "max_files_available": 5,
  "max_files_used": 50
"state": "online",
"snaplock_type": "non_snaplock",
"create_time": "2018-12-04T15:40:38-05:00",
"data_encryption": {
  "software_encryption_enabled": false,
  "drive_protection_enabled": false
"block_storage": {
  "primary": {
    "disk_count": 6,
    "disk_class": "solid_state",
    "raid_type": "raid_dp",
    "raid_size": 24,
    "checksum_style": "block",
    "disk_type": "ssd"
  "hybrid_cache": {
    "enabled": false
  "mirror": {
    "enabled": false,
    "state": "unmirrored"
  "plexes": [
      "name": "plex0",
"cloud_storage": {
  "attach_eligible": false
Retrieving statistics and metric for an aggregate
In this example, the API returns the "statistics" and "metric" properties for the aggregate requested.
#The API:
/api/storage/aggregates/{uuid}?fields=statistics,metric
#The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/538bf337-1b2c-11e8-bad0-005056b48388?fields=statistics,metric" -H "accept: application/json"
#The response:
"uuid": "538bf337-1b2c-11e8-bad0-005056b48388",
"name": "aggr4",
"metric": {
     "timestamp": "2019-07-08T22:16:45Z",
     "duration": "PT15S",
     "status": "ok",
     "throughput": {
       "read": 7099,
       "write": 840226,
       "other": 193293789,
       "total": 194141115
     "latency": {
       "read": 149,
       "write": 230,
       "other": 123,
       "total": 124
     "iops": {
       "read": 1,
       "write": 17,
       "other": 11663,
       "total": 11682
  "statistics": {
     "timestamp": "2019-07-08T22:17:09Z",
     "status": "ok",
     "throughput_raw": {
       "read": 3106045952,
       "write": 63771742208,
       "other": 146185560064,
       "total": 213063348224
     "latency_raw": {
       "read": 54072313,
       "write": 313354426,
       "other": 477201985,
       "total": 844628724
     "iops_raw": {
       "read": 328267,
       "write": 1137230,
       "other": 1586535,
       "total": 3052032
For more information and examples on viewing historical performance metrics for any given aggregate, see DOC /storage/aggregates/{uuid}/metrics
Simulating aggregate expansion
The following example shows the response for a simulated data aggregate expansion based on the values of the 'block_storage.primary.disk_count' attribute passed in. The query does not modify the existing aggregate but returns how the aggregate will look after the expansion along with any associated warnings. Simulated data aggregate expansion will be blocked while one or more nodes in the cluster are simulating or implementing automatic aggregate creation. This will be reflected in the following attributes:
  • space.block_storage.size - Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve.
  • block_storage.primary.disk_count - Number of disks that could be used to create the aggregate.
# The API:
/api/storage/aggregates/{uuid}?simulate=true
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/aggregates/cae60cfe-deae-42bd-babb-ef437d118314?simulate=true" -H "accept: application/json" -d "{\"block_storage\": {\"primary\": {\"disk_count\": 14}}}"
# The response:
"warnings": [
    "name": "node_2_SSD_1",
    "warning": {
      "message": "One or more disks will not be added. 14 disks specified, 13 disks will be added.",
      "code": 787170,
      "arguments": [
        "14",
        "13"
"num_records": 1,
"records": [
    "uuid": "cae60cfe-deae-42bd-babb-ef437d118314",
    "node": {
      "uuid": "4046dda8-f802-11e8-8f6d-005056bb2030",
      "name": "node-2",
            "href": "/api/cluster/nodes/4046dda8-f802-11e8-8f6d-005056bb2030"
    "space": {
      "block_storage": {
        "size": 1116180480
    "block_storage": {
      "primary": {
        "disk_count": 23,
        "disk_type": "ssd"
      "hybrid_cache": {
        "enabled": false
      "mirror": {
        "enabled": false
"job": {
      "href": "/api/storage/aggregates/cae60cfe-deae-42bd-babb-ef437d118314"
Retrieving a recommendation for an aggregate expansion
The following example shows the response with the recommended data aggregate expansion based on what disks are present within the system. The query does not modify the existing aggregate but returns how the aggregate will look after the expansion. The recommendation will be reflected in the attributes - 'space.block_storage.size' and 'block_storage.primary.disk_count'. Recommended data aggregate expansion will be blocked while one or more nodes in the cluster are simulating or implementing automatic aggregate creation.
# The API:
/api/storage/aggregates/{uuid}?auto_provision_policy=expand
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/cae60cfe-deae-42bd-babb-ef437d118314?auto_provision_policy=expand" -H "accept: application/json"
# The response:
"node": {
  "name": "node-2",
"space": {
  "block_storage": {
    "size": 1116180480
"block_storage": {
  "primary": {
    "disk_count": 23,
    "disk_type": "ssd"
  "hybrid_cache": {
    "enabled": false
  "mirror": {
    "enabled": false
Updating an aggregate in the cluster
The following example shows the workflow of adding disks to the aggregate.
Step 1: Check the current disk count on the aggregate.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/19425837-f2fa-4a9f-8f01-712f626c983c?fields=block_storage.primary.disk_count" -H "accept: application/json"
# The response:
"name": "test1",
"block_storage": {
  "primary": {
    "disk_count": 6
Step 2: Update the aggregate with the new disk count in 'block_storage.primary.disk_count'. The response to PATCH is a job unless the request is invalid.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/aggregates/19425837-f2fa-4a9f-8f01-712f626c983c" -H "accept: application/hal+json" -d "{\"block_storage\": {\"primary\": {\"disk_count\": 8}}}"
# The response:
"job": {
  "uuid": "c103d15e-730b-11e8-a57f-005056b465d6",
      "href": "/api/cluster/jobs/c103d15e-730b-11e8-a57f-005056b465d6"
Step 3: Wait for the job to finish, then call GET to see the reflected change.
# The API:
# The call:
# The response:
"name": "test1",
"block_storage": {
  "primary": {
    "disk_count": 8
The following example shows the workflow to enable software encryption on an aggregate.
Step 1: Check the current software encryption status of the aggregate.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/f3aafdc6-be35-4d93-9590-5a402bffbe4b?fields=data_encryption.software_encryption_enabled" -H "accept: application/json"
# The response:
"uuid": "f3aafdc6-be35-4d93-9590-5a402bffbe4b",
"name": "aggr5",
Step 2: Update the aggregate with the encryption status in 'data_encryption.software_encryption_enabled'. The response to PATCH is a job unless the request is invalid.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/aggregates/f3aafdc6-be35-4d93-9590-5a402bffbe4b" -H "accept: application/hal+json" -d '{"data_encryption": {"software_encryption_enabled": "true"}}'
# The response:
"job": {
  "uuid": "6b7ab28e-168d-11ea-8a50-0050568eca76",
      "href": "/api/cluster/jobs/6b7ab28e-168d-11ea-8a50-0050568eca76"
# The API:
# The call:
# The response:
"name": "aggr5",
  "software_encryption_enabled": true
