ONTAP REST API Storage volumes volume.uuid top-metrics users endpoints
Overview
You can use this API to retrieve a list of users with the most IO activity for a specified volume. Use the top_metric parameter to specify which type of IO activity to filter for. This API is used to provide insight into IO activity and supports ordering by IO activity types, namely iops or throughput metrics. This API also supports only returning one IO activity type per request.
Retrieve a list of the users with the most IO activity
For a report on the users with the most IO activity returned in descending order, specify the IO activity type you want to filter for by passing the iops or throughput property into the top_metric parameter. If the IO activity type is not specified, by default the API returns a list of the users with the greatest number of the average read operations per second. The maximum number of users returned by the API for an IO activity type is 25.
– GET /api/storage/volumes/{volume.uuid}/top-metrics/users
Retrieving a list of the users with the greatest average number of read bytes received per second:
# The API:
# The Call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/top-metrics/users?top_metric=throughput.read"
# The Response:
"records": [
"volume": {
"name": "vol1"
"throughput": {
"read": 1495,
"error": {
"lower_bound": 1495,
"upper_bound": 1502
"user_id": "S-1-5-21-256008430-3394229847-3930036330-1001",
"user_name": "John",
"svm": {
"uuid": "572361f3-e769-439d-9c04-2ba48a08ff43",
"name": "vs1",
"href": "/api/svm/svms/572361f3-e769-439d-9c04-2ba48a08ff43"
"volume": {
"name": "vol1"
"throughput": {
"read": 1022,
"error": {
"lower_bound": 1022,
"upper_bound": 1025
"user_id": "1988",
"user_name": "Ryan",
"svm": {
"name": "vs1",
"volume": {
"name": "vol1"
"throughput": {
"read": 345,
"error": {
"lower_bound": 345,
"upper_bound": 348
"user_id": "S-1-5-21-256008430-3394229847-3930036330-1003",
"user_name": "Julie",
"svm": {
"name": "vs1",
"num_records": 3,
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/top-metrics/users?top_metric=throughput.read"
