View and create Vscan configuration
Use Vscan configuration endpoints to manage how your storage systems interact with antivirus software, ensuring data protection against viruses and malicious code. These endpoints facilitate the configuration of scanning operations, allowing you to control the scope and timing of scans executed by external servers hosting third-party antivirus solutions.
Overview
Use Vscan to protect data from being compromised by viruses or other malicious code. Vscan combines best-in-class third party antivirus software with ONTAP features that give you the flexibility you need to control which files get scanned and when. Storage systems offload scanning operations to external servers hosting antivirus software from third party vendors. An Antivirus Connector on the external server handles communications between the storage system and the antivirus software.
Retrieving all of the Vscan configurations
# The API:
/api/protocols/vscan
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "03ce5c36-f269-11e8-8852-0050568e5298",
"name": "vs1"
"enabled": true,
"scanner_pools": [
"name": "scanner-1",
"servers": [
"1.1.1.1",
"10.72.204.27"
"privileged_users": [
"cifs\\u1",
"cifs\\u2"
"role": "primary",
"cluster": {
"name": "Cluster1",
"uuid": "0228714d-f268-11e8-8851-0050568e5298"
"name": "scanner-2",
"servers": [
"1.1.1.1",
"10.72.204.27"
"cifs\\u1",
"cifs\\u2"
"role": "primary",
"cluster": {
"name": "Cluster1",
"on_access_policies": [
"name": "default_CIFS",
"vsName": "vs1",
"enabled": true,
"mandatory": true,
"scope": {
"max_file_size": 2147483648,
"include_extensions": [
"scan_without_extension": true,
"scan_readonly_volumes": false,
"only_execute_access": false
"name": "on-access-test1",
"vsName": "vs1",
"enabled": false,
"mandatory": true,
"scope": {
"max_file_size": 10000,
"exclude_paths": [
"\\dir"
"mp*",
"txt"
"exclude_extensions": [
"mp*",
"txt"
"name": "on-access-test2",
"vsName": "vs1",
"enabled": false,
"mandatory": true,
"scope": {
"exclude_paths": [
"\\dir"
"mp*",
"txt"
"mp*",
"txt"
"on_demand_policies": [
"name": "task-1",
"scan_paths": [
"/vol1"
"log_path": "/vol1",
"scope": {
"exclude_paths": [
"/vol1"
"vmdk",
"mp*"
"mp3",
"mp4"
"name": "task-2",
"scan_paths": [
"/vol1"
"log_path": "/vol2",
"scope": {
"exclude_paths": [
"/vol2"
"vmdk",
"mp*"
"mp3",
"mp4"
"svm": {
"uuid": "24c2567a-f269-11e8-8852-0050568e5298",
"name": "vs2"
"enabled": false,
"scanner_pools": [
"name": "sp2",
"servers": [
"1.1.1.1"
"cifs\\u1"
"role": "idle"
"vsName": "vs2",
"enabled": true,
"mandatory": true,
"scope": {
"name": "ap1",
"vsName": "vs2",
"enabled": false,
"mandatory": true,
"scope": {
"name": "t1",
"scan_paths": [
"/vol1"
"scope": {
"max_file_size": 10737418240,
"num_records": 2
Retrieving all Vscan configurations for a particular SVM
# The API:
/api/protocols/vscan/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/24c2567a-f269-11e8-8852-0050568e5298?fields=*" -H "accept: application/json"
# The response:
"svm": {
"name": "vs2"
"enabled": false,
"scanner_pools": [
"name": "sp2",
"servers": [
"1.1.1.1"
"cifs\\u1"
"role": "idle"
"vsName": "vs2",
"enabled": true,
"mandatory": true,
"scope": {
"name": "ap1",
"vsName": "vs2",
"enabled": false,
"mandatory": true,
"scope": {
"name": "t1",
"scan_paths": [
"/vol1"
"scope": {
Creating a Vscan configuration
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan?return_records=true" -H "accept: appication/json" -H "Content-Type: application/json" -d "{ \"enabled\": true, \"on_access_policies\": [ { \"enabled\": true, \"mandatory\": true, \"name\": \"on-access-test\", \"scope\": { \"exclude_extensions\": [ \"mp*\", \"txt\" ], \"exclude_paths\": [ \"\\\\vol\" ], \"include_extensions\": [ \"mp*\", \"txt\" ], \"max_file_size\": 21474, \"only_execute_access\": false, \"scan_readonly_volumes\": false, \"scan_without_extension\": true } } ], \"on_demand_policies\": [ { \"log_path\": \"/vol\", \"name\": \"task-1\", \"scan_paths\": [ \"/vol\" ], \"schedule\": { \"name\": \"daily\", \"uuid\": \"d4984822-17b7-11e9-b450-0050568ecd85\" }, \"scope\": { \"exclude_extensions\": [ \"mp3\", \"mp4\" ], \"exclude_paths\": [ \"/vol\" ], \"include_extensions\": [ \"vmdk\", \"mp*\" ], \"max_file_size\": 10737, \"scan_without_extension\": true } } ], \"scanner_pools\": [ { \"cluster\": { \"name\": \"Cluster1\", \"uuid\": \"ab746d77-17b7-11e9-b450-0050568ecd85\" }, \"name\": \"scanner-1\", \"privileged_users\": [ \"cifs\\\\u1\", \"cifs\\\\u2\" ], \"role\": \"primary\", \"servers\": [ \"1.1.1.1\", \"10.72.204.27\" ] } ], \"svm\": { \"name\": \"vs1\", \"uuid\": \"b103be27-17b8-11e9-b451-0050568ecd85\" }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"uuid": "b103be27-17b8-11e9-b451-0050568ecd85",
"name": "vs1"
"enabled": true,
"scanner_pools": [
"servers": [
"1.1.1.1",
"10.72.204.27"
"cifs\\u1",
"cifs\\u2"
"role": "primary",
"cluster": {
"name": "Cluster1",
"uuid": "ab746d77-17b7-11e9-b450-0050568ecd85"
"name": "on-access-test",
"enabled": true,
"mandatory": true,
"scope": {
"max_file_size": 21474,
"exclude_paths": [
"\\vol"
"mp*",
"txt"
"mp*",
"txt"
"name": "task-1",
"scan_paths": [
"/vol"
"log_path": "/vol",
"schedule": {
"uuid": "d4984822-17b7-11e9-b450-0050568ecd85",
"name": "daily"
"scope": {
"max_file_size": 10737,
"exclude_paths": [
"vmdk",
"mp*"
"mp3",
"mp4"
Creating multiple Vscan scanner-pools for the specified SVM
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan?return_records=true" -H "accept: appication/json" -H "Content-Type: application/json" -d "{ \"scanner_pools\": [ { \"cluster\": { \"name\": \"Cluster1\", \"uuid\": \"ab746d77-17b7-11e9-b450-0050568ecd85\" }, \"name\": \"scanner-1\", \"privileged_users\": [ \"cifs\\\\u1\", \"cifs\\\\u2\" ], \"role\": \"primary\", \"servers\": [ \"1.1.1.1\", \"10.72.204.27\" ] }, { \"cluster\": { \"name\": \"Cluster1\", \"uuid\": \"ab746d77-17b7-11e9-b450-0050568ecd85\" }, \"name\": \"scanner-2\", \"privileged_users\": [ \"cifs\\\\u3\", \"cifs\\\\u4\" ], \"role\": \"primary\", \"servers\": [ \"1.1.1.5\", \"10.72.3.27\" ] } ], \"svm\": { \"name\": \"vs1\", \"uuid\": \"b103be27-17b8-11e9-b451-0050568ecd85\" }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"scanner_pools": [
"servers": [
"1.1.1.1",
"10.72.204.27"
"cifs\\u1",
"cifs\\u2"
"role": "primary",
"cluster": {
"name": "Cluster1",
"servers": [
"1.1.1.5",
"10.72.3.27"
"cifs\\u3",
"cifs\\u4"
"role": "primary",
"cluster": {
"name": "Cluster1",
Creating multiple Vscan On-access policies for a specified SVM
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"on_access_policies\": [ { \"enabled\": false, \"mandatory\": true, \"name\": \"on-access-test11\", \"scope\": { \"exclude_extensions\": [ \"mp*\", \"txt\" ], \"exclude_paths\": [ \"\\\\vol\" ], \"include_extensions\": [ \"mp*\", \"txt\" ], \"max_file_size\": 214748, \"only_execute_access\": false, \"scan_readonly_volumes\": false, \"scan_without_extension\": true } }, { \"enabled\": false, \"mandatory\": true, \"name\": \"on-access-test10\", \"scope\": { \"exclude_extensions\": [ \"mp*\", \"txt\" ], \"exclude_paths\": [ \"\\\\vol\" ], \"include_extensions\": [ \"mp*\", \"txt\" ], \"max_file_size\": 21474, \"only_execute_access\": false, \"scan_readonly_volumes\": false, \"scan_without_extension\": true } } ], \"svm\": { \"name\": \"vs1\", \"uuid\": \"b103be27-17b8-11e9-b451-0050568ecd85\" }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"name": "on-access-test11",
"enabled": false,
"mandatory": true,
"scope": {
"max_file_size": 214748,
"exclude_paths": [
"\\vol"
"mp*",
"txt"
"mp*",
"txt"
"name": "on-access-test10",
"enabled": false,
"mandatory": true,
"scope": {
"exclude_paths": [
"\\vol"
"mp*",
"txt"
"mp*",
"txt"
Creating multiple Vscan On-demand policies for a specified SVM
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"on_demand_policies\": [ { \"log_path\": \"/vol\", \"name\": \"task-1\", \"scan_paths\": [ \"/vol\" ], \"schedule\": { \"name\": \"daily\", \"uuid\": \"d4984822-17b7-11e9-b450-0050568ecd85\" }, \"scope\": { \"exclude_extensions\": [ \"mp3\", \"mp4\" ], \"exclude_paths\": [ \"/vol1\" ], \"include_extensions\": [ \"vmdk\", \"mp*\" ], \"max_file_size\": 107374, \"scan_without_extension\": true } }, { \"log_path\": \"/vol\", \"name\": \"task-2\", \"scan_paths\": [ \"/vol\" ], \"scope\": { \"exclude_extensions\": [ \"mp3\", \"mp4\" ], \"exclude_paths\": [ \"/vol1\" ], \"include_extensions\": [ \"vmdk\", \"mp*\" ], \"max_file_size\": 107374, \"scan_without_extension\": true } } ], \"svm\": { \"name\": \"vs1\", \"uuid\": \"b103be27-17b8-11e9-b451-0050568ecd85\" }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"name": "task-1",
"scan_paths": [
"/vol"
"log_path": "/vol",
"schedule": {
"name": "daily"
"scope": {
"max_file_size": 107374,
"exclude_paths": [
"/vol1"
"vmdk",
"mp*"
"mp3",
"mp4"
"name": "task-2",
"scan_paths": [
"/vol"
"log_path": "/vol",
"scope": {
"exclude_paths": [
"/vol1"
"vmdk",
"mp*"
"mp3",
"mp4"
Enabling Vscan for a specified SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/vscan/03ce5c36-f269-11e8-8852-0050568e5298" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"enabled\": true}"
Clearing the Vscan cache for the specified SVM
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/vscan/03ce5c36-f269-11e8-8852-0050568e5298" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"cache_clear\": true}"
Deleting the Vscan configuration for a specified SVM
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/vscan/03ce5c36-f269-11e8-8852-0050568e5298" -H "accept: application/json"
