REST API reference
Delete an IP route
Deletes a specific IP route when you need to remove it from the network configuration.
HTTP method and endpoint
DELETE /network/ip/routes/{uuid}
Introduced in
ONTAP 9.6
  • network route delete
uuid
string
path
True
Route UUID
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
