REST API reference
Delete locks for a parameter
Deletes locks on a specified parameter. This operation is typically used to manage access and modify configurations for that parameter.
HTTP method and endpoint
DELETE /protocols/locks/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Deletes locks of given parameter.
  • vserver locks break
uuid
string
path
True
Lock ID
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
