Disassociate SnapLock audit logs
Disassociates a SnapLock volume from being used as the audit log volume for an SVM. Use this when you need to close all active log files and disable the volume for SnapLock logging.
HTTP method and endpoint
DELETE /storage/snaplock/audit-logs/{svm.uuid}
Introduced in
ONTAP 9.7
Usage notes
Disassociates a SnapLock volume as the audit log volume for an SVM. This API closes all the active log files in the log volume and marks the volume as disabled for SnapLock logging.
Related ONTAP commands
snaplock log delete
Learn more
svm.uuid |
string |
path |
True |
SVM UUID |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
