Retrieve a cloud target
Accesses a specific cloud target by using its UUID to obtain detailed information about the target's configuration.
HTTP method and endpoint
GET /cloud/targets/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the cloud target specified by the UUID.
Related ONTAP commands
storage aggregate object-store config show
uuid |
string |
path |
True |
Cloud target UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
access_key |
string |
Access key ID for AWS_S3 and other S3 compatible provider types. |
authentication_type |
string |
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST. |
azure_account |
string |
Azure account |
cap_url |
string |
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword, and session token) for accessing the object store. |
certificate_validation_enabled |
boolean |
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
cluster |
container |
string |
Data bucket/container name. For FabricLink, a wildcard character "*" can also be specified to indicate that all the buckets in an SVM can use the same target information. However, for containers other than ONTAP, an exact name should be specified.
ipspace |
IPspace to use in order to reach the cloud target. |
name |
string |
Cloud target name |
owner |
string |
Owner of the target. Allowed values are FabricPool, SnapMirror or S3_SnapMirror. A target can be used by only one feature. |
port |
integer |
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
provider_type |
string |
Type of cloud provider. Allowed values depend on owner type. For FabricPool, AliCloud, AWS_S3, Azure_Cloud, GoggleCloud, IBM_COS, SGWS, and ONTAP_S3 are allowed. For SnapMirror, the valid values are AWS_S3 or SGWS. For FabricLink, AWS_S3, SGWS, S3_Compatible, S3EMU, LOOPBACK and ONTAP_S3 are allowed.
server |
string |
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3- |
server_side_encryption |
string |
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. This is an advanced property. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
snapmirror_use |
string |
Use of the cloud target by SnapMirror. |
ssl_enabled |
boolean |
SSL/HTTPS enabled or not |
svm |
This field is only applicable when used for SnapMirror and FabricLink. For POST and PATCH, SVM information is required for SnapMirror and FabricLink targets and not allowed for FabricPool targets. |
url_style |
string |
URL style used to access S3 bucket. |
use_http_proxy |
boolean |
Use HTTP proxy when connecting to the object store. |
used |
integer |
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes. |
uuid |
string |
Cloud target UUID |
"href": "/api/resourcelink"
"access_key": "string",
"authentication_type": "string",
"azure_account": "string",
"cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
"cluster": {
"name": "string",
"uuid": "string"
"container": "bucket1",
"ipspace": {
"name": "exchange",
"name": "string",
"owner": "string",
"provider_type": "string",
"server": "string",
"server_side_encryption": "string",
"snapmirror_use": "string",
"svm": {
"name": "svm1",
"url_style": "string",
"used": 0,
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster
name |
string |
The name of the cluster that owns the cloud target. For POST, this accepts the name of the peer cluster only if the cluster is in switchover state. |
uuid |
string |
The UUID of the cluster that owns the cloud target. For POST, this accepts the UUID of the peer cluster only if the cluster is in switchover state. |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
