Retrieve FC logins
Retrieves Fibre Channel (FC) login information, which helps you monitor and manage connectivity in your network environment.
HTTP method and endpoint
GET /network/fc/logins
Introduced in
ONTAP 9.6
Usage notes
Retrieves FC logins.
Related ONTAP commands
vserver fcp initiator show
Learn more
NVMe: DOC /network/fc/logins
protocol |
string |
query |
False |
Filter by protocol |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
igroups.name |
string |
query |
False |
Filter by igroups.name
igroups.uuid |
string |
query |
False |
Filter by igroups.uuid |
initiator.port_address |
string |
query |
False |
Filter by initiator.port_address |
initiator.wwpn |
string |
query |
False |
Filter by initiator.wwpn |
initiator.comment |
string |
query |
False |
Filter by initiator.comment
initiator.wwnn |
string |
query |
False |
Filter by initiator.wwnn |
initiator.aliases |
string |
query |
False |
Filter by initiator.aliases |
interface.name |
string |
query |
False |
Filter by interface.name |
interface.wwpn |
string |
query |
False |
Filter by interface.wwpn |
interface.uuid |
string |
query |
False |
Filter by interface.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[fc_login] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"next": {
"igroups": [
"name": "igroup1",
"initiator": {
"aliases": [
"alias1"
"comment": "This is an FC initiator for host 5",
"port_address": "5060A",
"wwnn": "2f:a0:00:a0:98:0b:56:13",
"wwpn": "2f:a0:00:a0:98:0b:56:13"
"interface": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"protocol": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
igroups
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
initiator
Information about the logged in FC initiator.
aliases |
array[string] |
The logged in initiator world wide port name (WWPN) aliases. |
comment |
string |
A comment available for use by the administrator. This is modifiable from the initiator REST endpoint directly. See PATCH /protocols/san/igroups/{igroup.uuid}/initiators/{name} . |
port_address |
string |
The port address of the initiator's FC port. Each port in an FC switched fabric has its own unique port address for routing purposes. The port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the initiator port. This is useful for obtaining statistics and diagnostic information from FC switches. This is a hexadecimal encoded numeric value. |
wwnn |
string |
The logged in initiator world wide node name (WWNN). |
wwpn |
string |
The logged in initiator WWPN. |
interface
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
fc_login
A Fibre Channel (FC) login represents a connection formed by an FC initiator that has successfully logged in to ONTAP. This represents the FC login on which higher-level protocols such as Fibre Channel Protocol and NVMe over Fibre Channel (NVMe/FC) rely.
_links |
igroups |
array[igroups] |
The initiator groups in which the initiator is a member. |
initiator |
Information about the logged in FC initiator. |
interface |
An FC interface. |
protocol |
string |
The data protocol used to perform the login. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
