REST API reference
Retrieve status of an FPolicy server
Retrieves the status of an FPolicy server to monitor its current state and ensure it is functioning as expected.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/connections/{node.uuid}/{policy.name}/{server}
Introduced in
ONTAP 9.10
  • vserver fpolicy show-engine
svm.uuid
string
path
True
node.uuid
string
path
True
Node UUID.
policy.name
string
path
True
Policy name
server
string
path
True
FPolicy Server IP address
Status: 200, Ok
Name Type Description
_links
_links
disconnected_reason
disconnected_reason
Indicates the reason for FPolicy server disconnection.
node
node
policy
fpolicy_policy_reference
server
string
IP address of the FPolicy server.
session_uuid
string
Unique session ID associated with each connection to the FPolicy server and it can be used to identify the established connection.
state
string
Specifies the FPolicy server connection state indicating if it is in the connected or disconnected state. The following is a list of the possible states:
  • connected - Connected
  • disconnected - Disconnected
svm
svm
type
string
FPolicy server type. The possible values are:
  • primary - Primary server
  • secondary - Secondary server
update_time
string
Specifies the time at which FPolicy server is connected or disconnected.
      "href": "/api/resourcelink"
  "disconnected_reason": {
    "code": 9370,
    "message": "TCP Connection to FPolicy server failed."
  "node": {
    "name": "node1",
  "policy": {
    "name": "string"
  "server": "10.132.145.20",
  "session_uuid": "5224ec64-b336-11eb-841c-0050568e14c2",
  "state": "connected",
  "svm": {
    "name": "svm1",
  "type": "primary",
  "update_time": "2019-06-12T11:00:16-04:00"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
disconnected_reason
code
integer
Reason ID for the FPolicy Server disconnection.
message
string
FPolicy server reason for disconnection message.
node
_links
_links
name
string
uuid
string
self
_links
self_link
name
string
The name of the FPolicy Policy name.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
