REST API reference
Retrieve S3 bucket configurations for an SVM
Retrieves the S3 bucket configurations for a specific SVM to access detailed settings and policies for your storage management tasks.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 bucket's configuration of an SVM. Note that in order to retrieve S3 bucket policy conditions, the 'fields' option should be set to '**'.
  • vserver object-store-server bucket show
  • vserver object-store-server bucket policy statement show
  • vserver object-store-server bucket policy-statement-condition show
encryption.enabled
boolean
query
False
Filter by encryption.enabled
role
string
query
False
Filter by role
  • Introduced in: 9.10
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
qos_policy.uuid
string
query
False
Filter by qos_policy.uuid
  • Introduced in: 9.8
qos_policy.min_throughput_mbps
integer
query
False
Filter by qos_policy.min_throughput_mbps
qos_policy.name
string
query
False
Filter by qos_policy.name
qos_policy.max_throughput_mbps
integer
query
False
Filter by qos_policy.max_throughput_mbps
qos_policy.min_throughput_iops
integer
query
False
Filter by qos_policy.min_throughput_iops
qos_policy.max_throughput_iops
integer
query
False
Filter by qos_policy.max_throughput_iops
audit_event_selector.access
string
query
False
Filter by audit_event_selector.access
audit_event_selector.permission
string
query
False
Filter by audit_event_selector.permission
uuid
string
query
False
Filter by uuid
policy.statements.resources
string
query
False
Filter by policy.statements.resources
policy.statements.principals
string
query
False
Filter by policy.statements.principals
policy.statements.conditions.operator
string
query
False
Filter by policy.statements.conditions.operator
policy.statements.conditions.usernames
string
query
False
Filter by policy.statements.conditions.usernames
policy.statements.conditions.prefixes
string
query
False
Filter by policy.statements.conditions.prefixes
policy.statements.conditions.delimiters
string
query
False
Filter by policy.statements.conditions.delimiters
policy.statements.conditions.source_ips
string
query
False
Filter by policy.statements.conditions.source_ips
policy.statements.conditions.max_keys
integer
query
False
Filter by policy.statements.conditions.max_keys
policy.statements.effect
string
query
False
Filter by policy.statements.effect
policy.statements.actions
string
query
False
Filter by policy.statements.actions
policy.statements.sid
string
query
False
Filter by policy.statements.sid
protection_status.is_protected
boolean
query
False
Filter by protection_status.is_protected
protection_status.destination.is_cloud
boolean
query
False
Filter by protection_status.destination.is_cloud
protection_status.destination.is_ontap
boolean
query
False
Filter by protection_status.destination.is_ontap
svm.name
string
query
False
Filter by svm.name
logical_used_size
integer
query
False
Filter by logical_used_size
size
integer
query
False
Filter by size
  • Max value: 70368744177664
  • Min value: 83886080
versioning_state
string
query
False
Filter by versioning_state
  • Introduced in: 9.11
comment
string
query
False
Filter by comment
  • maxLength: 256
  • minLength: 0
name
string
query
False
Filter by name
  • maxLength: 63
  • minLength: 3
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_bucket_svm]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "audit_event_selector": {
        "access": "string",
        "permission": "string"
      "comment": "S3 bucket.",
      "logical_used_size": 0,
      "name": "bucket1",
      "policy": {
        "statements": [
            "actions": [
              "GetObject",
              "PutObject",
              "DeleteObject",
              "ListBucket"
            "conditions": [
                "delimiters": [
                "max_keys": [
                  1000
                "operator": "ip_address",
                "prefixes": [
                  "pref"
                "source_ips": [
                  "1.1.1.1",
                  "1.2.2.0/24"
                "usernames": [
                  "user1"
            "effect": "allow",
            "principals": [
              "user1",
              "group/grp1"
            "resources": [
              "bucket1",
              "bucket1/*"
            "sid": "FullAccessToUser1"
      "qos_policy": {
        "max_throughput_iops": 10000,
        "max_throughput_mbps": 500,
        "min_throughput_iops": 2000,
        "min_throughput_mbps": 500,
        "name": "performance",
      "role": "string",
      "size": 1677721600,
      "svm": {
        "name": "svm1",
      "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
      "versioning_state": "enabled",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
aggregates
_links
_links
name
string
uuid
string
Event selector allows you to specify access and permission types to audit.
access
string
Specifies read and write access types.
permission
string
Specifies allow and deny permission types.
encryption
enabled
boolean
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket.
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters
array[string]
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
max_keys
array[integer]
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
operator
string
Condition operator that is applied to the specified condition key.
prefixes
array[string]
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
source_ips
array[string]
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
usernames
array[string]
An array of usernames that a current user in the context is evaluated against using the condition operators.
s3_bucket_policy_statement
Specifies information about a single access permission.
actions
array[string]
conditions
array[s3_bucket_policy_condition]
Specifies bucket policy conditions.
effect
string
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
principals
array[string]
resources
array[string]
sid
string
Specifies the statement identifier used to differentiate between statements.
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
statements
array[s3_bucket_policy_statement]
Specifies bucket access policy statement.
destination
is_cloud
boolean
Specifies whether a bucket is protected within the Cloud.
is_ontap
boolean
Specifies whether a bucket is protected within ONTAP.
  • Default value:
  • readOnly: 1
protection_status
Specifies attributes of bucket protection.
destination
destination
is_protected
boolean
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud.
  • Default value:
  • readOnly: 1
qos_policy
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
_links
_links
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
s3_bucket_svm
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
comment
string
Can contain any additional information about the bucket being created or modified.
encryption
encryption
logical_used_size
integer
Specifies the bucket logical used size up to this point.
name
string
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
policy
policy
protection_status
protection_status
qos_policy
qos_policy
role
string
Specifies the role of the bucket.
size
integer
Specifies the bucket size in bytes; ranges from 80MB to 64TB.
svm
svm
uuid
string
Specifies the unique identifier of the bucket.
versioning_state
string
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state.
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
