REST API reference
Retrieve login message configuration by UUID
Retrieves the login message configuration using its unique identifier to view the current settings. This helps you manage and verify login message configurations efficiently.
HTTP method and endpoint
GET /security/login/messages/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the login messages configuration by UUID.
uuid
string
path
True
Login messages configuration UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
banner
string
The login banner text. This message is displayed during SSH and console device login just before the password prompt displays. When configured, a cluster-level login banner is used for every incoming connection. Each data SVM can override the cluster-level banner to instead display when you log into the SVM. To restore the default setting for a data SVM, set the banner to an empty string. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body.
message
string
The message of the day (MOTD). This message appears just before the clustershell prompt after a successful login. When configured, the cluster message displays first. If you log in as a data SVM administrator, the SVM message is then printed. The cluster-level MOTD can be disabled for a given data SVM using the "show_cluster_message" property. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
boolean
Specifies whether to show a cluster-level message before the SVM message when logging in as an SVM administrator. This setting can only be modified by the cluster administrator. Optional in the PATCH body.
svm
svm
uuid
string
The unique identifier (ID) of the login messages configuration.
      "href": "/api/resourcelink"
  "banner": "string",
  "message": "string",
  "scope": "string",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
