REST API reference
Retrieve a multi-admin-verify request
Retrieves a multi-admin verification request, giving you access to the verification details needed for administrative purposes.
HTTP method and endpoint
GET /security/multi-admin-verify/requests/{index}
Introduced in
ONTAP 9.11
Usage notes
Retrieves a multi-admin-verify request.
index
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
approve_expiry_time
string
approve_time
string
approved_users
array[string]
The users that have approved the request.
comment
string
Optional user-provided comment that is sent to the approval-group email indicating why the request was made.
create_time
string
execution_expiry_time
string
index
integer
Unique index that represents a request.
operation
string
The command to execute.
owner
owner
The owner of the request. This can identify the cluster or an SVM.
pending_approvers
integer
The number of approvers remaining that are required to approve.
permitted_users
array[string]
List of users that can execute the operation once approved. If not set, any authorized user can perform the operation.
potential_approvers
array[string]
The users that are able to approve the request.
query
string
Identifies the specific entry upon which the user wants to operate.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
state
string
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required.
user_requested
string
The user that created the request. Automatically set by ONTAP.
  • readOnly: 1
  • Introduced in: 9.11
user_vetoed
string
The user that vetoed the request.
  "approve_expiry_time": "string",
  "approve_time": "string",
  "approved_users": [
    "string"
  "comment": "string",
  "create_time": "string",
  "execution_expiry_time": "string",
  "index": 0,
  "operation": "string",
  "owner": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "pending_approvers": 0,
  "permitted_users": [
    "string"
  "potential_approvers": [
    "string"
  "query": "string",
  "required_approvers": 0,
  "state": "string",
  "user_requested": "string",
  "user_vetoed": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
owner
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
