REST API reference
Retrieve a storage port
Retrieves details about a specific storage port, helping you manage and configure network connections for storage systems.
HTTP method and endpoint
GET /storage/ports/{node.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific storage port.
  • storage port show
Learn more
node.uuid
string
path
True
Node UUID
name
string
path
True
Port name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
board_name
string
cable
cable
description
string
enabled
boolean
error
error
firmware_version
string
force
boolean
in_use
boolean
Specifies whether any devices are connected through this port
mac_address
string
mode
string
Operational mode of a non-dedicated Ethernet port
name
string
node
node
part_number
string
redundant
boolean
Specifies whether all devices connected through this port have a redundant path from another port
serial_number
string
speed
number
Operational port speed in Gbps
state
string
type
string
wwn
string
World Wide Name
wwpn
string
World Wide Port Name
  "board_name": "string",
  "cable": {
    "identifier": "500a0980000b6c3f-50000d1703544b80",
    "length": "2m",
    "part_number": "112-00431+A0",
    "serial_number": "616930439"
  "description": "SAS Host Adapter 2a (PMC-Sierra PM8072 rev. C)",
  "error": {
    "corrective_action": "string",
    "message": "string"
  "firmware_version": "03.08.09.00",
  "mac_address": "string",
  "mode": "storage",
  "name": "2a",
  "node": {
        "href": "/api/resourcelink"
    "name": "node1",
  "part_number": "111-03801",
  "serial_number": "7A2463CC45B",
  "speed": "6",
  "state": "online",
  "type": "sas",
  "wwn": "50000d1703544b80",
  "wwpn": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
cable
identifier
string
length
string
part_number
string
serial_number
string
error
corrective_action
string
Error corrective action
message
string
Error message
string
self
node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
