REST API reference
Retrieve a tape device
Retrieves detailed information about a specific tape device. Use this endpoint to access the configuration and status of the tape device for management or troubleshooting purposes.
HTTP method and endpoint
GET /storage/tape-devices/{node.uuid}/{device_id}
Introduced in
ONTAP 9.9
Usage notes
Retrieves a specific tape device.
  • storage tape show
node.uuid
string
path
True
Node UUID
device_id
string
path
True
Device ID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
alias
alias
aliases
array[aliases]
block_number
integer
Block number.
density
string
Density.
description
string
device_id
string
device_names
array[device_names]
device_state
string
Operational state of the device.
file_number
integer
File number.
formats
array[string]
Tape cartridge format.
interface
string
Device interface type.
node
node
online
boolean
position
position
reservation_type
string
residual_count
integer
Residual count of the last I/O operation.
serial_number
string
storage_port
storage_port
type
string
Device type.
wwnn
string
World Wide Node Name.
wwpn
string
World Wide Port Name.
  "alias": {
    "mapping": "SN[10WT000933]",
    "name": "st6"
  "aliases": [
      "name": "st6"
  "block_number": 0,
  "density": "low",
  "description": "QUANTUM LTO-8 ULTRIUM",
  "device_id": "1a.0",
  "device_names": [
      "no_rewind_device": "nrst6l",
      "rewind_device": "rst6l",
      "unload_reload_device": "urst6l"
  "device_state": "read_write_enabled",
  "file_number": 0,
  "formats": [
    "LTO-7 6TB",
    "LTO-7 15TB Compressed",
    "LTO-8 12TB",
    "LTO-8 30TB Compressed"
  "interface": "sas",
  "node": {
        "href": "/api/resourcelink"
    "name": "node1",
  "position": {
    "count": 5,
    "operation": "rewind"
  "reservation_type": "off",
  "residual_count": 0,
  "serial_number": "10WT00093",
  "storage_port": {
    "name": "2b"
  "type": "tape",
  "wwnn": "500507631295741c",
  "wwpn": "500507631295741c"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
alias
mapping
string
This field will no longer be supported in a future release. Use aliases.mapping instead.
name
string
This field will no longer be supported in a future release. Use aliases.name instead.
aliases
mapping
string
Alias mapping.
name
string
Alias name.
device_names
no_rewind_device
string
Device name for no rewind.
rewind_device
string
Device name for rewind.
string
Device name for unload or reload operations.
string
self
node
_links
_links
name
string
uuid
string
position
count
integer
Number of times to run position operation.
operation
string
Position operation.
storage_port
name
string
Initiator port.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
