REST API reference
Retrieves a list of clients with the most io activity
GET /storage/volumes/{volume.uuid}/top-metrics/clients
Introduced In: 9.10
Retrieves a list of clients with the most IO activity.
volume.uuid
string
path
True
Volume UUID
top_metric
string
query
False
IO activity type
  • Default value: 1
  • enum: ["iops.read", "iops.write", "throughput.read", "throughput.write"]
volume.name
string
query
False
Filter by volume.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
iops.write
integer
query
False
Filter by iops.write
iops.error.upper_bound
integer
query
False
Filter by iops.error.upper_bound
iops.error.lower_bound
integer
query
False
Filter by iops.error.lower_bound
iops.read
integer
query
False
Filter by iops.read
throughput.error.upper_bound
integer
query
False
Filter by throughput.error.upper_bound
throughput.error.lower_bound
integer
query
False
Filter by throughput.error.lower_bound
throughput.write
integer
query
False
Filter by throughput.write
throughput.read
integer
query
False
Filter by throughput.read
client_ip
string
query
False
Filter by client_ip
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
notice
notice
Optional field that indicates why no records are returned by the volume activity tracking REST API.
num_records
integer
Number of records.
records
array[top_metrics_client]
    "next": {
      "href": "/api/resourcelink"
  "notice": {
    "code": "111411207",
    "message": "No read/write traffic on volume"
  "records": [
      "client_ip": "192.168.185.170",
      "iops": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 5,
        "write": 10
      "svm": {
        "name": "svm1",
      "throughput": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 12,
        "write": 2
      "volume": {
        "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
notice
code
string
Warning code indicating why no records are returned.
message
string
Details why no records are returned.
top_metric_value_error_bounds
lower_bound
integer
Lower bound of the nominal value of a metric.
upper_bound
integer
Upper bound of the nominal value of a metric.
iops
error
read
integer
Average number of read operations per second.
write
integer
Average number of write operations per second.
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
throughput
error
read
integer
Average number of read bytes received per second.
write
integer
Average number of write bytes received per second.
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
top_metrics_client
Information about a client's IO activity.
client_ip
string
IP address of the client. Both IPv4 and IPv6 IP addresses are supported.
iops
iops
svm
svm
throughput
throughput
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
