List files with the most I/O activity
Retrieves a list of files with the most I/O activity, helping you identify which files are heavily accessed or utilized.
HTTP method and endpoint
GET /svm/svms/{svm.uuid}/top-metrics/files
Introduced in
ONTAP 9.11
Usage notes
Retrieves a list of files with the most IO activity.
svm.uuid |
string |
path |
True |
SVM UUID |
top_metric |
string |
query |
False |
IO activity type
max_records_per_svm |
integer |
query |
False |
Max records per svm. |
path |
string |
query |
False |
Filter by path |
throughput.error.lower_bound |
integer |
query |
False |
Filter by throughput.error.lower_bound |
throughput.error.upper_bound |
integer |
query |
False |
Filter by throughput.error.upper_bound |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
iops.error.lower_bound |
integer |
query |
False |
Filter by iops.error.lower_bound |
iops.error.upper_bound |
integer |
query |
False |
Filter by iops.error.upper_bound |
iops.write |
integer |
query |
False |
Filter by iops.write |
iops.read |
integer |
query |
False |
Filter by iops.read |
volume.name |
string |
query |
False |
Filter by volume.name |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
junction-path |
string |
query |
False |
Filter by junction-path |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
excluded_volumes |
List of volumes that are not included in the SVM activity tracking REST API. |
notice |
Optional field that indicates why no records are returned by the SVM activity tracking REST API. |
num_records |
integer |
Number of records. |
records |
array[top_metrics_svm_file] |
"next": {
"href": "/api/resourcelink"
"excluded_volumes": [
"reason": {
"code": "111411207",
"message": "The volume is offline."
"volume": {
"name": "volume1",
"notice": {
"records": [
"metadata": {
"iops": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 5,
"write": 4
"junction-path": "/fv",
"path": "/vol/fv/dir_abc/dir_123/file_1",
"svm": {
"name": "svm1",
"throughput": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 2,
"write": 20
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
124519405 |
The activity tracking report for SVM svm.name returned zero records. Check whether the volumes belonging to the SVM have read/write traffic. Refer to the REST API documentation for more information on why there might be no records. |
124519406 |
Failed to get the activity tracking report for SVM svm.name. Reason: |
124519407 |
SVM wildcard queries are not supported for activity tracking reports. |
124519408 |
Activity tracking is not supported on SVM svm.name, because it is configured as a destination for SVM DR. |
124519409 |
Activity tracking is not supported on SVM svm.name, because it is configured as a destination of a MetroCluster SVM relationship and the SVM admin state is stopped. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
reason
code |
string |
Warning code indicating why the volume is not included in the SVM activity tracking REST API. |
message |
string |
Details why the volume is not included in the SVM activity tracking REST API. |
_links
self |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
top_metrics_svm_file_excluded_volume
List of volumes and their details as to why they are not included in the SVM activity tracking REST API.
reason |
volume |
notice
code |
string |
Warning code indicating why no records are returned. |
message |
string |
Details why no records are returned. |
_links
metadata |
self |
top_metric_value_error_bounds
lower_bound |
integer |
Lower bound of the nominal value of a metric. |
upper_bound |
integer |
Upper bound of the nominal value of a metric. |
iops
error |
read |
integer |
Average number of read operations per second. |
write |
integer |
Average number of write operations per second. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
throughput
error |
read |
integer |
Average number of read bytes received per second. |
write |
integer |
Average number of write bytes received per second. |
Information about a file's IO activity.
_links |
iops |
junction-path |
string |
Junction path of the file. |
path |
string |
Path of the file. |
svm |
throughput |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
