REST API reference
Manage cloud targets
Manage cloud targets in your ONTAP cluster by retrieving, creating, and deleting cloud target configurations. Use these endpoints to ensure reliable connectivity between ONTAP and your object store provider, facilitating efficient integration with external storage resources.
Retrieving a collection of cloud targets
The cloud targets GET API retrieves all cloud targets defined in the cluster.
Creating cloud targets
The cluster administrator tells ONTAP how to connect to a cloud target. The following pre-requisites must be met before creating an object store configuration in ONTAP. A valid data bucket or container must be created with the object store provider. This assumes that the user has valid account credentials with the object store provider to access the data bucket. The ONTAP node must be able to connect to the object store.
This includes:
  • Fast, reliable connectivity to the object store.
  • An inter-cluster LIF (logical interface) must be configured on the cluster. ONTAP verifies connectivity prior to saving this configuration information.
  • If SSL/TLS authentication is required, then valid certificates must be installed.
  • FabricPool license (required for all object stores except SGWS).
Deleting cloud targets
If a cloud target is used by an aggregate, then the aggregate must be deleted before the cloud target can be deleted.
