Manage storage file moves
Initiate and monitor file move operations between FlexVol volumes or within FlexGroup volumes using this API. This functionality is useful for managing file placement and optimizing storage capacity across your cluster.
Overview
You can use this API to start a file move operation between two FlexVol volumes or within a FlexGroup volume, and view the status of all on-going file move operations in the cluster.
– GET /api/storage/file/moves
– POST /api/storage/file/moves
Moving two files from one FlexVol volume to the other FlexVol volume
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/file/moves" -H "accept: application/hal+json" -d @move_between_fv.txt
move_between_fv.txt:
"files_to_move":{
"sources":[
"svm":{
"name":"vs0"
"volume":{
"name":"fv1"
"path":"dir1/f1.txt"
"svm":{
"name":"vs0"
"volume":{
"name":"fv1"
"path":"dir1/f2.txt"
"destinations":[
"svm":{
"name":"vs0"
"volume":{
"name":"fv2"
"path":"dir2/f1.txt"
"svm":{
"name":"vs0"
"volume":{
"name":"fv2"
"path":"dir2/f2.txt"
# The response:
Moving two files from one FlexVol volume to the other FlexVol volume (only specifying the destination directory)
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/file/moves" -H "accept: application/hal+json" -d @move_between_fv_dir.txt
move_between_fv_dir.txt:
"files_to_move":{
"sources":[
"svm":{
"name":"vs0"
"volume":{
"name":"fv1"
"path":"dir1/f3.txt"
"svm":{
"name":"vs0"
"volume":{
"name":"fv1"
"path":"dir1/f4.txt"
"destinations":[
"svm":{
"name":"vs0"
"volume":{
"name":"fv2"
"path":"dir2/"
# The response:
Moving multiple files from one FlexVol volume to the other FlexVol volume and providing a source reference file
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/file/moves" -H "accept: application/hal+json" -d @move_between_fv_source.txt
move_between_fv_source.txt:
"files_to_move":{
"sources":[
"svm":{
"name":"vs0"
"volume":{
"name":"fv1"
"path":"dir1/f5.txt"
"svm":{
"name":"vs0"
"volume":{
"name":"fv1"
"path":"dir1/f6.txt"
"svm":{
"name":"vs0"
"volume":{
"name":"fv1"
"path":"dir1/f7.txt"
"destinations":[
"svm":{
"name":"vs0"
"volume":{
"name":"fv2"
"path":"dir2/f5.txt"
"svm":{
"name":"vs0"
"volume":{
"name":"fv2"
"path":"dir2/f6.txt"
"svm":{
"name":"vs0"
"volume":{
"name":"fv2"
"path":"dir2/f700.txt"
"reference":{
"svm":{
"name":"vs0"
"volume":{
"name":"fv1"
# The response:
Moving a file between two FlexGroup volume constituents in the same FlexGroup volume
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/file/moves" -H "accept: application/hal+json" -d @move_between_fg.txt
move_between_fg.txt:
"files_to_move":{
"sources":[
"svm":{
"name":"vs0"
"volume":{
"name":"fg2"
"path":"test/file.txt"
"destinations":[
"volume":{
"name":"fg2__0008"
# The response:
Automatically selecting a destination constituent to move a file in a FlexGroup volume for capacity rebalancing
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/file/moves?automatic=true" -H "accept: application/hal+json" -d @move_between_fg_automatic.txt
move_between_fg_automatic.txt:
"files_to_move":{
"sources":[
"svm":{
"name":"vs0"
"volume":{
"name":"fg2"
"path":"test/file2.txt"
# The response:
Moving a file between two FlexGroup volume constituents in the same FlexGroup volume using the "force" option
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/file/moves?force=true" -H "accept: application/hal+json" -d @move_between_fg_force.txt
"files_to_move":{
"sources":[
"svm":{
"name":"vs0"
"volume":{
"name":"fg2"
"path":"test/file3.txt"
"destinations":[
"volume":{
"name":"fg2__0008"
# The response:
Retrieving file move operations
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/file/moves" -H 'accept: application/hal+json'
# The response:
"records": [
"node": {
"uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd",
"name": "node1",
"href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd"
"uuid": "e12bc78d-36bb-4274-8163-fb8c21d59c9b",
"index": 0,
"source": {
"svm": {
"uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd",
"name": "vs0"
"volume": {
"uuid": "4e919b6d-1c76-11ec-8e1b-005056acf2dd",
"name": "fg2__0008"
"path": "test/file2.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"uuid": "4d14f2f6-1c76-11ec-8e1b-005056acf2dd",
"name": "fg2__0005"
"href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/e12bc78d-36bb-4274-8163-fb8c21d59c9b/0"
"node": {
"name": "node1",
"uuid": "ce2af347-586d-4b31-b728-1e925f51fdfc",
"index": 1,
"source": {
"svm": {
"name": "vs0"
"volume": {
"uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd",
"name": "fv1"
"path": "dir1/f2.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd",
"name": "fv2"
"path": "dir2/f2.txt"
"href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/ce2af347-586d-4b31-b728-1e925f51fdfc/1"
"node": {
"name": "node1",
"index": 0,
"source": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv1"
"path": "dir1/f1.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv2"
"path": "dir2/f1.txt"
"href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/ce2af347-586d-4b31-b728-1e925f51fdfc/0"
"node": {
"name": "node1",
"uuid": "6d12601b-5377-43bf-99f0-b4bec37565e2",
"index": 0,
"source": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv1"
"path": "dir1/f3.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv2"
"path": "dir2/f3.txt"
"href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/6d12601b-5377-43bf-99f0-b4bec37565e2/0"
"node": {
"name": "node1",
"index": 1,
"source": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv1"
"path": "dir1/f4.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv2"
"path": "dir2/f4.txt"
"href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/6d12601b-5377-43bf-99f0-b4bec37565e2/1"
"node": {
"name": "node1",
"uuid": "bbfdface-0d46-4f5f-9624-72f4869eba81",
"index": 0,
"source": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv1"
"path": "dir1/f5.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv2"
"path": "dir2/f5.txt"
"href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/bbfdface-0d46-4f5f-9624-72f4869eba81/0"
"node": {
"name": "node1",
"index": 2,
"source": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv1"
"path": "dir1/f7.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv2"
"path": "dir2/f700.txt"
"href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/bbfdface-0d46-4f5f-9624-72f4869eba81/2"
"node": {
"name": "node1",
"index": 1,
"source": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv1"
"path": "dir1/f6.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"name": "fv2"
"path": "dir2/f6.txt"
"href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/bbfdface-0d46-4f5f-9624-72f4869eba81/1"
"node": {
"uuid": "780255d2-10aa-11ec-a308-005056acf86d",
"name": "node2",
"href": "/api/cluster/nodes/780255d2-10aa-11ec-a308-005056acf86d"
"uuid": "6591a42a-4ea2-4d40-bfb4-38959f6bd68e",
"index": 0,
"source": {
"svm": {
"name": "vs0"
"volume": {
"uuid": "438731dd-1c76-11ec-8e1b-005056acf2dd",
"name": "fg2__0001"
"path": "test/file.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"name": "fg2__0008"
"path": "/test/file.txt"
"href": "/api/storage/file/moves/780255d2-10aa-11ec-a308-005056acf86d/6591a42a-4ea2-4d40-bfb4-38959f6bd68e/0"
"node": {
"name": "node2",
"uuid": "1a94e95a-346e-4eb3-969a-110e275cbf18",
"index": 0,
"source": {
"svm": {
"name": "vs0"
"volume": {
"name": "fg2__0001"
"path": "test/file3.txt"
"destination": {
"svm": {
"name": "vs0"
"volume": {
"name": "fg2__0008"
"path": "/test/file3.txt"
"href": "/api/storage/file/moves/780255d2-10aa-11ec-a308-005056acf86d/1a94e95a-346e-4eb3-969a-110e275cbf18/0"
"num_records": 10,
"href": "/api/storage/file/moves"
