Manage Vscan On-Demand policies
Use these endpoints to manage Vscan On-Demand policy configurations, which define the scope and schedule for scanning files for viruses. Execute scans during off-peak hours or target specific file types and paths within the SVM namespace.
Overview
Vscan On-Demand scanning is used to check files for viruses on a schedule. For example, it can be used to run scans only in off-peak hours, or to scan very large files that are excluded from an on-access scan. Vscan On-Demand scanning can be used for any path in the SVM namespace.
Vscan On-Demand policy configurations define the scope of a Vscan On-Demand scan. The schedule parameter in the On-Demand policy configuration decides when to execute the task. Schedule can be created using the /api/clusters/schedule endpoint and can be assigned on policy create or policy modify. This API is used to retrieve and manage Vscan On-Demand policy configurations. It is also used to schedule the Vscan On-Demand scan.
Retrieving all fields for all policies of an SVM
# The API:
/api/protocols/vscan/{svm.uuid}/on-demand-policies/
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/{svm.uuid}/on-demand-policies?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "86fbc414-f140-11e8-8e22-0050568e0945",
"name": "vs1",
"href": "/api/svm/svms/86fbc414-f140-11e8-8e22-0050568e0945"
"name": "on-demand-policy1",
"scan_paths": [
"/vol1/",
"/vol2/cifs/"
"log_path": "/vol0/report_dir",
"schedule": {
"uuid": "f6d0843e-f159-11e8-8e22-0050568e0945",
"name": "schedule",
"href": "/api/cluster/schedules/f6d0843e-f159-11e8-8e22-0050568e0945"
"scope": {
"max_file_size": 10737418240,
"exclude_paths": [
"/vol1/cold-files/",
"/vol1/cifs/names"
"include_extensions": [
"vmdk",
"mp*"
"exclude_extensions": [
"mp3",
"mp4"
"scan_without_extension": false
"href": "/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-demand-policies/policy1"
"svm": {
"name": "vs1",
"name": "on-demand-policy2",
"scan_paths": [
"/vol1/",
"/vol2/cifs/"
"log_path": "/report",
"scope": {
"mp*"
"scan_without_extension": true
"href": "/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-demand-policies/policy2"
"num_records": 2,
"href": "/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-demand-policies?fields=*"
Retrieving a specific On-Demand policy associated with a specified SVM
# The API:
/api/protocols/vscan/{svm.uuid}/on-demand-policies/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-demand-policies/on-demand-task" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1",
"name": "on-demand-policy",
"scan_paths": [
"/vol1/cifs"
"scope": {
"vmdk",
"mp*"
Creating a Vscan On-Demand policy
The Vscan On-Demand policy POST endpoint creates an On-Demand policy for the specified SVM. Specify the schedule parameter to schedule an On-Demand scan.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-demand-policies?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"log_path\": \"/vol0/report_dir\", \"name\": \"on-demand-policy\", \"scan_paths\": [ \"/vol1/\", \"/vol2/cifs/\" ], \"schedule\": { \"name\": \"weekly\", \"uuid\": \"1cd8a442-86d1-11e0-ae1c-123478563412\" }, \"scope\": { \"exclude_extensions\": [ \"mp3\" ], \"exclude_paths\": [ \"/vol/cold-files/\" ], \"include_extensions\": [ \"vmdk\", \"mp*\" ], \"max_file_size\": 1073741824, \"scan_without_extension\": true }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"scan_paths": [
"/vol1/",
"/vol2/cifs/"
"schedule": {
"name": "weekly"
"scope": {
"max_file_size": 1073741824,
"exclude_paths": [
"/vol/cold-files/"
"vmdk",
"mp*"
"mp3"
Creating a Vscan On-Demand policy where a number of optional fields are not specified
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-demand-policies?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"log_path\": \"/report\", \"name\": \"on-demand-policy\", \"scan_paths\": [ \"/vol1/cifs/\" ], \"scope\": { \"include_extensions\": [ \"mp*\" ], \"scan_without_extension\": true }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"scan_paths": [
"vol1/cifs/"
"scope": {
"vmdk",
"mp*"
Updating a Vscan On-Demand policy
The policy being modified is identified by the UUID of the SVM and the policy name.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-demand-policies/on-demand-policy" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"schedule\": { \"name\": \"weekly\" }, \"scope\": { \"exclude_extensions\": [ \"mp3\" ], \"exclude_paths\": [ \"/vol/\" ], \"include_extensions\": [ \"vmdk\", \"mp3\" ], \"scan_without_extension\": true }}"
Deleting a Vscan On-Demand policy
The policy to be deleted is identified by the UUID of the SVM and the policy name.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-demand-policies/on-demand-policy" -H "accept: application/hal+json"
