REST API reference
ONTAP REST API Name-services cache group-membership settings endpoints
Overview
This API is used to retrieve and manage group-membership cache settings.
Retrieving group-membership cache settings
The following example shows how to use the cache group-membership settings GET endpoint to retrieve group-membership cache settings.
# The API:
GET /api/name-services/cache/group-membership/settings
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/group-membership/settings?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "8a1a8730-2036-11ec-8457-005056bbcfdb",
      "name": "vs43"
    "enabled": true,
    "ttl": "PT1H"
    "svm": {
      "uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef",
      "name": "vs34"
    "enabled": true,
    "ttl": "PT5M"
"num_records": 2
Retrieving group-membership cache settings for a given SVM
The following example shows how to use the cache group-membership settings GET endpoint to retrieve group-membership cache settings for a given SVM.
# The API:
GET /api/name-services/cache/group-membership/settings/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/group-membership/settings/dc458b2f-2035-11ec-bfe2-005056bb6bef" -H "accept: application/hal+json"
# The response:
"svm": {
  "name": "vs34"
"enabled": true,
"ttl": "PT1H"
Updating a group-membership cache setting
The following example shows how to use the cache group-membership settings PATCH endpoint to update a group-membership setting.
# The API:
PATCH /api/name-services/cache/group-membership/settings/{svm.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/unix-user/settings/02c9e252-41be-11e9-81d5-00a0986138f9" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"enabled\": \"false\" }"
