REST API reference
Create DNS domain and server configurations
Configures DNS domain and server settings for an SVM. Use this operation to establish or update DNS configurations, ensuring efficient domain name resolution within your storage environment.
HTTP method and endpoint
POST /name-services/dns
Introduced in
ONTAP 9.6
Usage notes
Creates DNS domain and server configurations for an SVM.
Important notes
  • Each SVM can have only one DNS configuration.
  • The domain name and the servers fields cannot be empty.
  • IPv6 must be enabled if IPv6 family addresses are specified in the servers field.
  • Configuring more than one DNS server is recommended to avoid a single point of failure.
  • The DNS server specified using the servers field is validated during this operation.
The validation fails in the following scenarios:
  1. The server is not a DNS server.
  2. The server does not exist.
  3. The server is unreachable.
    • The DNS server validation can be skipped by setting the property "skip_config_validation" to "true".
    • Scope of the SVM can be specified using the "scope" parameter. "svm" scope refers to data SVMs and "cluster" scope refers to clusters.
The following parameters are optional:
  • timeout
  • attempts
  • source_address_match
  • packet_query_match
  • tld_query_enabled
  • skip_config_validation
  • scope
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
attempts
integer
Number of attempts allowed when querying the DNS name servers.
domains
array[string]
A list of DNS domains. Domain names have the following requirements:
  • The name must contain only the following characters: A through Z, a through z, 0 through 9, ".", "-" or "_".
  • The first character of each label, delimited by ".", must be one of the following characters: A through Z or a through z or 0 through 9.
  • The last character of each label, delimited by ".", must be one of the following characters: A through Z, a through z, or 0 through 9.
  • The top level domain must contain only the following characters: A through Z, a through z.
  • The system reserves the following names:"all", "local", and "localhost".
packet_query_match
boolean
Indicates whether or not the query section of the reply packet is equal to that of the query packet.
scope
string
Set to "svm" for DNS owned by an SVM, otherwise set to "cluster".
servers
array[string]
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses.
boolean
Indicates whether or not the validation for the specified DNS configuration is disabled.
boolean
Indicates whether or not the DNS responses are from a different IP address to the IP address the request was sent to.
svm
svm
timeout
integer
Timeout values for queries to the name servers, in seconds.
tld_query_enabled
boolean
Enable or disable top-level domain (TLD) queries.
Example request
  "domains": [
    "example.com",
    "example2.example3.com"
  "scope": "string",
  "servers": [
    "10.224.65.20",
    "2001:db08:a0b:12f0::1"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of DNS domain records.
records
array[dns]
  "records": [
      "domains": [
        "example.com",
      "scope": "string",
      "servers": [
        "10.224.65.20",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2621706
The specified SVM UUID is incorrect for the specified SVM name
8847360
Only admin or data SVMs allowed
8847361
Exceeded the maximum number of domains allowed. Maximum of six domains only
8847362
Exceeded the maximum number of name servers allowed. Maximum of three name servers only
8847392
Domain name cannot be an IP address
8847393
Top level domain name is invalid
8847399
One or more of the specified DNS servers do not exist or cannot be reached
8847394
FQDN name violated the limitations
8847403
Scope specified is invalid for the specified SVM
9240587
FQDN name cannot be empty
9240588
FQDN name is too long. Maximum supported length: 255 characters
9240590
FQDN name is reserved. Following names are reserved: "all", "local" and "localhost"
9240607
One of the FQDN labels is too long. Maximum supported length is 63 characters
13434916
The SVM is in the process of being created. Wait a few minutes, and then try the command again.
23724130
Cannot use an IPv6 name server address because there are no IPv6 LIFs
string
dynamic_dns
enabled
boolean
Enable or disable Dynamic DNS (DDNS) updates for the specified SVM.
fqdn
string
Fully Qualified Domain Name (FQDN) to be used for dynamic DNS updates.
skip_fqdn_validation
boolean
Enable or disable FQDN validation.
time_to_live
string
Time to live value for the dynamic DNS updates, in an ISO-8601 duration formatted string. Maximum Time To Live is 720 hours(P30D in ISO-8601 format) and the default is 24 hours(P1D in ISO-8601 format).
use_secure
boolean
Enable or disable secure dynamic DNS updates for the specified SVM.
status
Status of each of the DNS name server configured for the specified SVM.
code
integer
Code corresponding to the status message. Code is 0 when the state is 'up'.
message
string
Detailed description of the validation state if the state is 'down' or the response time of the DNS server if the state is 'up'.
name_server
string
The IP address of the DNS server. The address can be either an IPv4 or an IPv6 address.
state
string
The validation status of the DNS server.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
dns
_links
_links
attempts
integer
domains
array[string]
packet_query_match
boolean
scope
string
servers
array[string]
boolean
boolean
svm
svm
timeout
integer
tld_query_enabled
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
