REST API reference
Start a file move operation
Initiates a file move operation to transfer files between FlexVol volumes or within a FlexGroup volume for capacity rebalancing. This action is useful when you need to manage storage efficiently by relocating files to optimize space usage.
HTTP method and endpoint
POST /storage/file/moves
Introduced in
ONTAP 9.11
Usage notes
Starts a file move operation. This API can be used to move files from one FlexVol volume to another FlexVol volume or within a FlexGroup volume for capacity rebalancing. For a FlexGroup volume file move operation, only one source file can be specified in files_to_move. The source volume is the FlexGroup volume. The destination volume is the destination FlexGroup volume constituent to move the file to. When automatic is true, destination volume is not required. The source path is the path to the file to be moved within the FlexGroup volume. If the destination path is specified, it must be the same as the source path.
Required properties for file move operation
  • files_to_move - List of files with the destination they are to be moved to.
Optional properties for file move operation
  • reference - The source reference file for moving multiple files.
Default property values
  • max_throughput - 0
  • max_cutover_time - 10
  • reference.max_cutover_time - 10
  • volume file move start
  • volume rebalance file-move start
force
boolean
query
False
If true, the FlexGroup volume file move operation breaks the existing lock state on the file being moved. Breaking the lock state may cause a disruption for some client applications.
  • Default value:
automatic
boolean
query
False
If true, the FlexGroup volume file move operation selects the destination constituent automatically.
  • Default value:
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
cutover_time
integer
Time that the file move operation takes before cutover completes, in seconds.
destination
destination
Destination file information.
elapsed_time
integer
Time elapsed since the start of the file move operation, in seconds.
files_to_move
files_to_move
A list of source files along with the destination file they are moved to. If the terminal path component of the destination is a directory, then the source file's basename is replicated in that directory. This is only used for FlexVol volume file move operations.
index
integer
An additional unique element identifying one file among many that could possibly be moved as part of a job. File index is an identifier ordered by the file path arrays provided during create. For file move operations that involve only one file, the file-index value of zero is always correct.
is_destination_ready
boolean
Indicates whether the destination file is ready for use.
is_flexgroup
boolean
Indicates whether this is a FlexGroup file move operation.
is_snapshot_fenced
boolean
Indicates whether Snapshot copies are fenced.
max_cutover_time
integer
The maximum amount of time, in seconds that the source can be quiesced before a destination file must be made available for read-write traffic. Not supported in FlexGroup volume file move operations.
max_throughput
integer
Maximum amount of data, in bytes that can be transferred per second in support of this operation. A non-zero value less than 1 MB/s is set to 1 MB/s. A non-zero value greater than 1 MB/s is truncated to the nearest integral megabyte value. If unspecified, the default value is "0" which means no range is set for the data transfer.
node
node
Node hosting the destination of this move operation.
reference
reference
scanner
scanner
source
source
Source file information.
uuid
string
The UUID which uniquely identifies the job that started this move operation.
Example request
  "cutover_time": 8,
  "destination": {
    "path": "d1/d2/file1",
    "svm": {
      "name": "svm1",
    "volume": {
      "name": "volume1",
  "elapsed_time": 100,
  "files_to_move": {
    "destinations": [
        "svm": {
          "name": "svm1",
        "volume": {
          "name": "volume1",
    "sources": [
        "svm": {
          "name": "svm1",
        "volume": {
          "name": "volume1",
  "index": 0,
  "max_cutover_time": 10,
  "max_throughput": 250000,
  "node": {
    "name": "node1",
  "reference": {
    "max_cutover_time": 5,
    "path": "string",
    "svm": {
      "name": "svm1",
    "volume": {
      "name": "volume1",
  "scanner": {
    "percent": 80,
    "progress": 80000,
    "state": "string",
    "total": 100000
  "source": {
    "svm": {
      "name": "svm1",
    "volume": {
      "name": "volume1",
  "uuid": "4fcb3159-a4ee-42b5-bb16-f752f2c430fc"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
7012352
File locations are inconsistent. All files must be on the same volume.
7012353
Exceeded the file operations supported number of files.
7012354
Unable to pair the number of source files to destination files.
7012357
Cannot start a file operation until all cluster nodes support the file operations capability.
7012358
The specified source path is invalid.
7012359
The specified destination path is invalid.
7012360
The SVMs are not in an intracluster peering relationship.
7012361
The SVMs peering relationship does not include application "file-move".
7012362
The SVMs are not yet in a peered state.
7012363
Cannot move files. All file operations must be managed by the destination SVM's administrator.
7012365
Copying a file between clusters is not supported.
7012367
A reference path may only be specified if multiple source paths are specified.
7012368
The reference path must have a matching source path.
7012371
The reference cutover time exceeds the maximum allowable time.
7012374
Source volume and destination volume have different home clusters.
7012376
Operation not allowed on a volume that is part of a SnapMirror Synchronous relationship.
7012377
Cannot start a file move operation on the volume because an active volume conversion is in progress.
144179206
Source file does not exist.
144179207
Volume capacity balancing requires an effective cluster version of 9.10.1 or later.
144180200
Destination constituent not a member of FlexGroup volume.
144180201
Destination constituent not properly configured.
144180206
File movement with automatic destination constituent selection only supported on FlexGroup volumes with more than one constituent.
196608143
Cannot start the operation. The volume is undergoing a secure purge operation.
string
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
destination
path
string
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
Contains the most recent failure reason for move operation.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
destinations
path
string
svm
svm
volume
volume
sources
path
string
svm
svm
volume
volume
files_to_move
destinations
array[destinations]
The destination file information.
sources
array[sources]
The source file information.
node
name
string
uuid
string
svm
SVM of the source reference file.
name
string
uuid
string
volume
Volume of the source reference file.
name
string
uuid
string
reference
max_cutover_time
integer
The maximum amount of time, in seconds that the source reference file can be quiesced before the corresponding destination file must be made available for read-write traffic. Not supported in FlexGroup volume file move operations.
path
string
The source reference file. If a reference file is specified, data for other files being moved will be transferred as a difference from the reference file. This can save bandwidth and destination storage if the specified source files share blocks. If provided, this input must match one of the source file paths. This input need not be provided if only one source file is specified. Not supported in FlexGroup volume file move operations.
svm
svm
volume
volume
scanner
percent
integer
Scanner progress, as a percentage.
progress
integer
Scanner progress, in bytes scanned.
state
string
Status of the file move scanner.
total
integer
Total bytes to be scanned.
source
path
string
svm
svm
volume
volume
svm
SVM of the FlexGroup volume in file move operation. Only used in a FlexGroup volume file move operation.
name
string
uuid
string
volume
name
string
uuid
string
file_move
Details of a file move operation.
cutover_time
integer
destination
destination
elapsed_time
integer
files_to_move
files_to_move
index
integer
boolean
is_flexgroup
boolean
is_snapshot_fenced
boolean
max_cutover_time
integer
max_throughput
integer
node
node
reference
reference
scanner
scanner
source
source
uuid
string
error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
