Security gcp-kms endpoint overview
Overview
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This feature
allows ONTAP to securely store its encryption keys using Google Cloud KMS.
In order to use Google Cloud KMS with ONTAP, a user must first deploy a Google Cloud application with appropriate access to the Google Cloud KMS and then provide
ONTAP with the necessary details, such as, project ID, key ring name, location, key name and application credentials to allow ONTAP to communicate
with the deployed Google Cloud application.
The properties state, google_reachability and ekmip_reachability are considered advanced properties and are populated only when explicitly requested.
Enabling GCKMS for an SVM
The following example shows how to enable GCKMS at the SVM-scope. Note the return_records=true query parameter is used to obtain the newly created key manager configuration.
# The API:
POST /api/security/gcp-kms
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/gcp-kms?return_records=true' -H 'accept: application/hal+json' -d '{"svm":{"uuid":"f36ff553-e713-11ea-bd56-005056bb4222" }, "project_id": "testProj", "key_ring_name":"testKeyRing", "key_ring_location": "global", "key_name": "key1", "application_credentials": "myAppCred"}'
# The response:
"num_records": 1,
"records": [
"uuid": "f72098a2-e908-11ea-bd56-005056bb4222",
"svm": {
"uuid": "f36ff553-e713-11ea-bd56-005056bb4222",
"name": "vs0"
"key_ring_name": "testKeyRing",
"key_name": "key1",
"href": "/api/security/gcp-kms/f72098a2-e908-11ea-bd56-005056bb4222"
Retrieving all GCKMS configurations
The following example shows how to retrieve all GCKMS configurations.
# The API:
GET /api/security/gcp-kms
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/gcp-kms?fields=*'
# The response:
"records": [
"scope": "svm",
"svm": {
"name": "vs0"
"key_name": "key1",
"num_records": 1,
"href": "/api/security/gcp-kms?fields=*"
Retrieving a specific GCKMS configuration
The following example shows how to retrieve information for a specific GCKMS configuration.
# The API:
GET /api/security/gcp-kms/{uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/gcp-kms/f72098a2-e908-11ea-bd56-005056bb4222?fields=*'
# The response:
"scope": "svm",
"svm": {
"name": "vs0"
"key_name": "key1",
Retrieving a specific GCKMS's advanced properties
The following example shows how to retrieve advanced properties for a specific GCKMS configuration.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/gcp-kms/f72098a2-e908-11ea-bd56-005056bb4222?fields=state,google_reachability,ekmip_reachability'
# The response:
"state": {
"cluster_state": false,
"message": "The Google Cloud Key Management Service key protection is unavailable on the following nodes: cluster1-node1.",
"code": 65537708
"google_reachability": {
"reachable": true,
"message": "",
"code": 0
"ekmip_reachability": [
"node": {
"uuid": "d208115f-7721-11eb-bf83-005056bb150e",
"name": "node1",
"href": "/api/cluster/nodes/d208115f-7721-11eb-bf83-005056bb150e"
"reachable": true,
"message": "",
"code": 0
"node": {
"uuid": "e208115f-7721-11eb-bf83-005056bb150e",
"name": "node2",
"href": "/api/cluster/nodes/e208115f-7721-11eb-bf83-005056bb150e"
"reachable": true,
"message": "",
"code": 0
Updating the application credentials of a specific GCKMS configuration
The following example shows how to update the application credentials for a specific GCKMS configuration.
# The API:
PATCH /api/security/gcp-kms/{uuid}
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/gcp-kms/f72098a2-e908-11ea-bd56-005056bb4222/' -d '{"application_credentials": "newAppCred"}'
Deleting a specific GCKMS configuration
The following example shows how to delete a specific GCKMS configuration.
# The API:
DELETE /api/security/gcp-kms/{uuid}
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/security/gcp-kms/f72098a2-e908-11ea-bd56-005056bb4222'
Restoring keys from KMIP server
The following example shows how to retore keys for a GCKMS configuration.
# The API:
POST /api/security/gcp-kms/{uuid}/restore
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/gcp-kms/33820b57-ec90-11ea-875e-005056bbf3f0/restore'
