ONTAP REST API Security multi-admin-verify requests endpoints
Overview
These APIs provide information about multi-admin verification requests.
If you need to execute a command that is protected by a multi-admin rule, you must first submit a request to be allowed to execute the command.
The request must then be approved by the designated approvers according to the rule associated with the command.
Creating a multi-admin-verify request
Creates a request for the specified ONTAP operation.
# The API:
/api/security/multi-admin-verify/requests
# The call:
curl -X POST "https://<mgmt-ip>/api/security/multi-admin-verify/requests?return_records=true" -H "accept: application/hal+json" -d '{"operation": "volume delete", "query": "-vserver vs0 -volume v1", "permitted_users": ["user1","user2"]}'
# The response:
"num_records": 1,
"records": [
"index": 10,
"state": "pending",
"required_approvers": 2,
"pending_approvers": 2,
"user1",
"user2"
"user_requested": "admin",
"owner": {
"uuid": "c1483186-6e73-11ec-bc92-005056a7ad04",
"name": "cluster1",
"href": "/api/svm/svms/c1483186-6e73-11ec-bc92-005056a7ad04"
"create_time": "2022-01-06T16:59:49-05:00",
"approve_expiry_time": "2022-01-06T19:59:49-05:00",
"href": "/api/security/multi-admin-verify/requests/10"
Retrieving multi-admin-verify requests
Retrieves information about multi-admin verification requests.
# The API:
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/requests"
# The response:
"records": [
"index": 1,
"href": "/api/security/multi-admin-verify/requests/1"
"index": 2,
"href": "/api/security/multi-admin-verify/requests/2"
"num_records": 2,
"href": "/api/security/multi-admin-verify/requests"
