ONTAP REST API Storage ports endpoints
Retrieving storage port information
The storage port GET API retrieves all of the storage ports in the cluster.
1) Retrieve a list of storage ports from the cluster
The following example shows the response with a list of storage ports in the cluster:
# The API:
/api/storage/ports
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/ports" -H "accept: application/hal+json"
# The response:
"records": [
"node": {
"uuid": "0530d6c1-8c6d-11e8-907f-00a0985a72ee",
"name": "node-1",
"href": "/api/cluster/nodes/0530d6c1-8c6d-11e8-907f-00a0985a72ee"
"name": "0a",
"href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0a"
"node": {
"name": "node-1",
"name": "0b",
"href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0b"
"node": {
"name": "node-1",
"name": "0c",
"href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0c"
"node": {
"name": "node-1",
"name": "0d",
"href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0d"
"node": {
"name": "node-1",
"name": "0e",
"href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0e"
"node": {
"name": "node-1",
"name": "0f",
"href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0f"
"node": {
"name": "node-1",
"name": "0g",
"href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0g"
"num_records": 7,
"href": "/api/storage/ports"
2) Retrieve a specific storage port from the cluster
The following example shows the response of the requested storage port. If there is no storage port with the requested node uuid and name, an error is returned.
# The API:
/api/storage/ports/{node.uuid}/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0a" -H "accept: application/hal+json"
# The response:
"node": {
"name": "node-1",
"name": "0a",
"description": "SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C)",
"wwn": "500a098003633df0",
"speed": 6,
"cable": {
"part_number": "112-00429+A0",
"serial_number": "629230774",
"identifier": "500a0980066e2c01-500a098003633df0",
"length": "0.5m"
"state": "online",
"enabled": true,
"firmware_version": "01.12.09.00",
"type": "sas",
"redundant": true,
"in_use": true,
Updating a storage port
The storage port PATCH API modifies the port mode for storage/network use and allows the port to be enabled/disabled.
1) Using an Ethernet port for storage
The following example sets an Ethernet port mode for storage use:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/e3a" -H "accept: application/hal+json" -H "Content-Type: application/hal_json" -d '{"mode": "storage"}'
# The response:
2) Disabling a storage port
The following example disables an unused storage port:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/e3a" -H "accept: application/hal+json" -H "Content-Type: application/hal_json" -d '{"enabled": "false"}'
# The response:
