REST API reference
ONTAP REST API Support ems filters endpoints
Overview
Manages the list of available filters. A filter is a named collection of rules that enable the system to identify events that require additional handling. A filter is linked with a destination to which the system sends specific events.
When EMS processes an event, each filter is evaluated for a match. More than one filter can handle a single event.
Note The system defines default filters that cannot be removed or modified. These filters are specified by setting the "system_defined" field to "true".
Filter rule position
A filter's rules are evaluated sequentially, according to their position index. When a rule is added or modified, the position can be set to customize the filter's logic. If no position is specified, a new rule is appended to the end of the list.
Filter rule types
A filter rule can be one of two types: 'include' or 'exclude'. If an event matches the criteria of the rule, the type dictates whether it should be forwarded to the destination or ignored.
Filter rule matching criteria
A valid filter rule must contain at least one set of criteria.
Name pattern
A name pattern is matched against an event's name. Multiple characters can be matched using the wildcard character '*'.
Severity
The severity pattern is matched against an event's severity. Multiple severities can be specified in a comma separated list. A single wildcard '*' will match all severities. Valid values are:
  • emergency
  • alert
  • error
  • notice
  • informational
  • debug
SNMP trap type
The SNMP trap type pattern is matched against an event's trap type. Multiple trap types can be specified in a comma separated list. A single wildcard '*' matches all trap types. Valid values are:
  • standard
  • built_in
  • severity_based
Retrieving a list of filters whose names contain a hyphen
# The API:
GET /api/support/ems/filters
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters?name=*-*" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
    "name": "default-trap-events",
        "href": "/api/support/ems/filters/default-trap-events"
    "name": "important-events",
        "href": "/api/support/ems/filters/important-events"
    "name": "no-info-debug-events",
        "href": "/api/support/ems/filters/no-info-debug-events"
"num_records": 3,
    "href": "/api/support/ems/filters?name=*-*"
Creating a new filter using various matching criteria
# The API:
POST /api/support/ems/filters
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_post.txt"
test_ems_filters_post.txt(body):
"name": "test-filter",
"rules": [
    "index": 1,
    "type": "include",
    "message_criteria": {
      "name_pattern": "LUN.*",
      "severities": "alert,error",
      "snmp_trap_types": "severity_based"
# The response:
201 Created
