Delete a schedule
Deletes a schedule when you need to remove it from the system, ensuring that the associated tasks are no longer executed.
HTTP method and endpoint
DELETE /cluster/schedules/{uuid}
Introduced in
ONTAP 9.6
uuid |
string |
path |
True |
Schedule UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
459758 |
Cannot delete a job schedule that is in use. Remove all references to the schedule, and then try to delete again. |
459761 |
Schedule cannot be deleted on this cluster because it is replicated from the remote cluster. |
459762 |
The schedule cannot be deleted because it is a system-level schedule. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
